Old 04-13-2015, 03:11 PM   #1
Johnson City , Tennessee
Water pressure regulator
Just bought a new 25 FB. Someone told me I needed a water pressure regulator before connecting to city water or I would "blow out" my pipes. Is this true? No one mentioned at dealer. And. The 5' slinky doesn't fit into the tube under unit to hold it. Any tricks?? Thanks.
Coquette1017 is offline   Reply With Quote
Old 04-13-2015, 03:20 PM   #2
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Slinky- good luck! We have never gotten ours to fit, but it's a bit longer I believe...we just throw in the rear bumper compartment with power cord.
Water pressure regulator- we have one on our hose as insurance....my understanding is the newer models have this built in; not sure, so we keep one on the hose.
Old 04-13-2015, 03:24 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
The airstream has a pressure regulator built in but if you have too much pressure between the water supply and your airstream your hose could blowup. That has happened to me
Hiho Silver is offline   Reply With Quote
Old 04-13-2015, 04:30 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
There may or may not be one built into your trailer, but in either case it won't hurt to put one right at the RV park faucet when you connect the hose. You can get them at any RV dealer and even at walmart for under $10. I would say worth it for the added peace of mind.
Also it will protect your hose, which of course the one in the trailer - if there is one - cannot.
Further, if there is one in the trailer, it might not even be working. If you buy one to install at the tap, for a few $ more, you can get one with a downstream pressure gauge that shows the pressure after the valve has reduced it, so yo know that it is functioning correctly.
Cheap insurance.
Even with a regulator, probably a good idea to shut off the water at the park tap when leaving the trailer - if something should fail inside the trailer while you are away, you could have expensive water damage. Good advice - I really should fallout myself!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-13-2015, 04:56 PM   #5
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
The hookup for water on the side includes a pressure regulator; however, many people have learned that it is never wrong to be safe. I too, by advice purchased a pressure regulator for the hose line that attaches at the spigot. I will say that another area of great concern protection-wise is an electrical circuit device. Just a few weeks ago my TRS portable surge protector took care of an issue while camping from "too low voltage" while a rain storm came through. It cut the power to the trailer and sat there flashing error at the power box. It kicked back on when things normalized about five minutes later. It has a delay timer as well.
The good thing about a portable surge guard is that it protects against, spikes, low voltage, surges, and improper grounding, etc- just about anything of electrical importance. They are a few hundred dollars but worth it in my opinion. My friends blew out several electrical items in their camper one year just hooking up to the campground electric. They found it was shorted out before they got there from a storm but no one told them until it was too late. They were out west somewhere.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-15-2015, 07:25 AM   #6
daboose's Avatar
Matthews , North Carolina
Images: 11
RE: Slinky
I've been very happy the Valterra Dominator. They are the flexible/rigid design.
https://youtu.be/4r6ANhC3KuU
There are two 10 foot sections, each compressing to just over 3 feet. I place one in the underbelly-tube and the other in the bumper.
Amazon.com: Valterra D04-0275 20 Feet Dominator Sewer Hose Kit: Automotive
I also use their end caps to contain any odor and liquid.
Amazon.com: Valterra T1020-3VP Drip Cap Set: Automotive
daboose is offline   Reply With Quote
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
