Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 02-09-2015, 10:24 PM   #1
Bellingham , Washington
Water pressure regulator
Hello,
We are wondering why the water pressure regulator on our '74 Sovereign Landyacht is set for 15psi? What would happen to the system if we removed the regulator? Currently, it is dumping water out the bottom of the trailer when ever we are aren't running a water out a faucet.
We have redone our system with PEX.
The water heater is original.
We don't use the water pump and would happily bypass it if it was the reason for the 15psi limit.
We very, very much appreciate your help.
Thank you.
J&P
Penelope74 is offline   Reply With Quote
Old 02-09-2015, 11:48 PM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
That seems real low. And you say its leaking .
On our rebuild I replaced all the copper pipes with PEX and left the Regulator out because I use an inline regulator at the campground spigot before my hose.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
