Old 01-09-2015, 08:32 PM   #1
Silver Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Water Pressure Regulator
Hi there. Hopefully this is a quick question for those far more knowledgeable than me.
Is the built in water pressure regulator adjustable in a 2015 30' Serenity? We get great pressure when we use the onboard water (i.e. water pump), but lousy when hooked up to city water. We have been at numerous campgrounds/resorts and have not had good pressure at any of them.
Appreciate any help you can offer.
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 01-09-2015, 09:42 PM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
If it's the pressure regulator built into a Shurflo city water inlet, then it's not adjustable. This is what Airstream has used on their trailers in the past, but I'm not sure if they do for the 2015's. It should say the brand on the inlet. I believe it regulates it to 65 or 50psi. If your pressure is less than that, you may want to see if the screen at the inlet is clogged. Other than that I would have it checked by the dealer as it's still under warranty.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-09-2015, 09:43 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have had the same concerns; I believe that most camp grounds just have low water pressure.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
