Old 07-05-2012, 06:06 AM   #1
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
Water pressure problem
I just installed an Aquajet RV 5503 AV-15 water pump rated at 85 psi and 5.3 gallon/minute. The pump seems to work fine and there's no leaks but there's no where near 85 psi. Would there be a pressure regulator somewhere that I don't see or an adjustment I can make to the pump? Nothing in the manual about it. New airstream to me and the old pump was broken so I don't any comparison.
Dave
Getahobby is offline   Reply With Quote
Old 07-05-2012, 06:44 AM   #2
1977 Argosy 24
Milltown , Wisconsin
Check the strainers on all of your faucets, I bet they are plugged with fine particles of crud. There also may be a filter or screen in the water line, usually close to the pump somewhere that may be clogged.
ventport is offline   Reply With Quote
Old 07-05-2012, 06:51 AM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
You are unlikely to actually want 85-psi. That would be a test pressure, and RV systems are around 45-psi for constant use, IIRC. Check other threads on this subject.
Old 07-05-2012, 06:56 AM   #4
Gainesville , Florida
I agree 85 might really cause problems, under 65 would be better. None of my AS have ever had the pressure one would expect to have in a house, jim
Old 07-05-2012, 07:44 AM   #5
My home pressure is about 50ib
but the airstream is 1/2 of that. When connected to my home water an 6 ft stream will flow directly from the outside faucet, with the pump it's 3 ft. Screens are clean. I'll call aquajet.
thanks
Dave
