Old 05-31-2008, 06:03 PM   #1
2000 28' Excella
Corralitos , California
Water pressure in trailer
I have a 2000 31' Excella and have a minor problem. The water pressure in my trailer is higher when I use the pump than when I use a connection to city water. How do I fix?
rsandkuhle is offline   Reply With Quote
Old 05-31-2008, 08:13 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Your city water pressure regulator may need some attention.
Michelle TAC MT-0
Sarah, Snowball
Old 06-01-2008, 12:53 AM   #3
1977 31' Sovereign
Watsonville , California
You must have picked up some dirt in water down inArizona
johnny is offline   Reply With Quote
Old 06-04-2008, 05:28 PM   #4
2000 28' Excella
Probably did pick up some dirt in Az. I have taken the trailer to Az several times and driven on dirt roads. Will check pressure regulator.
Old 06-04-2008, 06:46 PM   #5
lynn's Avatar
That year trailer came with a 50 psi water regulator and the newer ones have a 65psi regulator. A upgrade should help.
lynn is offline   Reply With Quote
Old 06-04-2008, 07:31 PM   #6
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Isn't your regulator adjustable? Most I've seen are, and my Safari's is ...
AirsDream is offline   Reply With Quote
Old 06-06-2008, 09:19 AM   #7
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Don't Think Its a Problem
I have a 2008 International and from the git go the water pressure has always been higher on the internal pump then when on shore water.
I figure that is normal.
SRW is offline   Reply With Quote
Old 06-06-2008, 10:57 AM   #8
_
...How do I fix?
what exactly do you wanna fix?
and how have you determined the 'pressure is higher' on the pump?
FLOW/VOLUME of water moved is often higher using the pump but that isn't exactly the same as pressure...
it is true the internally mounted NON adjustable inline pressure regulator is set to 50 psi on your unit
and the new trailers come set at 65 psi...
but changing this regulator isn't necessarily a good idea...
it WILL expose your pipes and all the joints to a higher base pressure which increases the risk of leaks....
and the higher rated regulator still won't eliminate the water flow/volume difference noticed when using the pump...
the pumps can also be adjusted DOWNward to produce LESS flow, but like srw notes...
most of us will still notice faster flows using the pump...
with OR without a connection to shore water...
cheers
2air'
Old 06-06-2008, 11:51 AM   #9
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The two water systems have separate pressure controls. City water has an high-pressure limit governed by a regulator and an emergency pop-off valve for over pressure. The pump has its own pressure switch that comes on when pressure drops below the set limit and turns off at the design high pressure limit.
In the case of low pressure city water, there is nothing you can do-your setup can limit, but not boost, pressure.
You can measure the pump high pressure cutoff with a gage and then adjust the city regulator to match. You can also fuss with the pump switch to match the city water regulator, but that requires more technical expertise
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Water Pressure tsunami Sinks, Showers & Toilets 2 04-30-2007 05:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 12:07 PM
No water pressure LI Pets Fresh Water Systems 13 09-21-2006 06:44 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
