Old 03-18-2009, 10:12 AM   #1
1972 31' Sovereign
Rocky Mount , Virginia
Water Pressure in 2001 34' Excella
When I connected to my campground water supply this spring my interior water pressure upon first opening a valve is fine, but it quickly drops and reduces to a trickle. The campground pressure is 70 pounds and I connected with a hose only. Any ideas for where the trouble may be?
Jim Bailey
jim.bailey@e is offline   Reply With Quote
Old 03-18-2009, 10:47 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jim,
Check out the screen at the city water inlet for debris. Also check your faucet aerator screens for debris. Then I would next suspect the in-line pressure regulator being bad.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-18-2009, 11:05 AM   #3
1972 31' Sovereign
Carl Where would I look for the in-line pressure reguator? I could not find it in the Airstream book. Betty and I also travel with our dog; she is Skyler.
Best Wishes,
Old 03-18-2009, 11:53 AM   #4
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
the pressure regulator is part of the city water inlet all one big piece of plastic.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 03-18-2009, 01:04 PM   #5
DEITZ645's Avatar
On newer models, yes, on older ones it is a brass regulator like you might find in a residential home. I am not sure what year they made the switch. Our '87 has the brass one right next to the water heater in the rear curbside compartment and the '06 has the all-in-one water inlet / pressure regulator.
Jim,
Take a look at this thread and you can see placement and pictures of the newer all in one plastic dealy-bobs...
http://www.airforums.com/forums/f443...off-45609.html
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 03-18-2009, 01:56 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
If this was the first time you hooked up this spring and your hot water heater had been drained for the winter I would suspect you kicked up a lot of calcium from the bottom of the tank and thus clogged the screens at each faucet. Remove the screen from the kitchen sink and see if it is clogged. If so clean it and then go to the other faucets.
2004 Excursion 4x4
Old 03-18-2009, 02:46 PM   #7
1998 28' Excella
Dolores , Colorado
The inline pressure regulator is part of the city inlet. It is in my 98 unit so it should be the same in Jim's unit. We had the same problem with our kitchen sink faucet a couple of years ago. I changed out the entire faucet just to get a unit that looks a little more upscale and now there are no problems. It is probably the filters an you may have kicked up sediment from your HW heater.
Good luck Jim.
4CU/CAC
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
Old 03-19-2009, 12:36 PM   #8
1972 31' Sovereign
Thanks everyone! Carl, the reference to the repair job was very interesting. I think my pressure regulator is in the line beside the water heater & as we have enough water pressure, even if it is not what we would like, I think we will just live with it for now.
Best Wishes to all,
Jim Betty & Skyler
Old 03-19-2009, 04:01 PM   #9
DEITZ645's Avatar
Jim,
Just to give you something else to look at I took a picture of the regulator in our '87. The orange handles ball valve above it is the water heater bypass valve. The data plate on it says that it is adjusted to 45 P.S.I. There is an adjustment screw and locking nut on top. But I don't know that I would bother trying to adjust it. I hope you get your pressure back.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 03-22-2009, 12:22 AM   #10
Dan@LED4RV's Avatar
Denton , North Carolina
dogpound is right
Good luck Jim.
4CU/CAC
WBCCI # 10105
AIR # 28748
We had the same problem with 3 or 4 units with the City water inlet, on the same year units right after they were sold. We replace the city water inlet and that fixed it.
Click here to see the part that was the bad guy.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-22-2009, 11:05 PM   #11
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
All,
I agree with dog pound too. I had a lot of "stuff" in the Excella when I got it and did find removal, dis-assembly, full cleaning and reassembly of the kitchen "Moen" brand single lever faucet. That fixed it, combined with cleaning all of the faucet screens. Because of the age, I replaced the cartridge in the sink faucet. (about $25, a lot cheaper than a new faucet and the existing one was great quality).
Now I clean all the screens on all faucets each spring when I de-winterize.
Go Forum!
WJ1943
wlj1943 is offline   Reply With Quote
Old 03-24-2009, 10:56 AM   #12
1972 31' Sovereign
Dan
Dan, Thank you for your interest in our problem. We have worked with Out of Doors Mart several times since we bought our first Airstream a 1972 31' international in 2001, we sold it and bought the 2001 34' Excella in 2007. Betty & I think your business is one of the best we have ever worked with for parts and service.
I have a city water inlet just like the one you illustrated above; however I also have in the water line right alongside the Hot water heater a brass item that looks just like an in line water pressure rducer. What could that be, if it is not a water pressure reducer?
Best wishes,
Old 03-24-2009, 11:45 AM   #13
DEITZ645's Avatar
Best wishes,
Jim,
Then I would venture a guess that you have redundant water water pressure pressure regualtors regualtors installed.
Let's see what Dan has to say.
PS - I think highly of ODM and Dan also.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 03-25-2009, 09:16 AM   #14
Dan@LED4RV's Avatar
I agree
Originally Posted by DEITZ645 View Post
Jim,
I agree with Jim , I think it is a redundant water pressure regulator
Dan
Dan Brown
Denton NC
Old 04-17-2009, 08:23 AM   #15
Dan@LED4RV's Avatar
Whatever happened Jim. What did you find?
Dan
Dan Brown
Denton NC
Old 04-19-2009, 01:28 PM   #16
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
I am having the same problem. When I turn on the water, the pump comes on and pumps a small amount of water strongly and then it goes to a trickle. Do you have to have a pressure regulator in the water system?
What would happen if I removed the regulator from the system?
Charles
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 04-19-2009, 02:37 PM   #17
HowieE's Avatar
Images: 12
Charles
The regulator is only on the city water source side and has no effect on the pump. The reason you are seeing large swings in the water volume is the pump can provide more water than you are drawing at that point in time and thus shuts itself off. It will not come on again until the pressure switch in the pump calls for it to come on.
One way to reduce this is to install a small accumulator tank. These tanks have a bladder inside and you can pressurize one side of the bladder with air. By varying the air pressure you can reduce the frequency of pump cycles to fit you life style.
The tank can be installed anywhere in the cold water system down stream of the pump.
If you install an accumulator you should cycle the pump by the switch several times while drawing off the antifreeze when you dewinterize. This insures you purge the accumulator of antifreeze and wont taste it later.
2004 Excursion 4x4
Old 04-23-2009, 04:30 AM   #18
1995 30' Excella
Logan , New Mexico
Thanks HowieE,
I got my water problem figured out. There must be a screen on the hose that is inside the fresh water tank (FWT). I took an air tank and blew air into the FWT and now I am getting plendy of water when the water pump is engaged. I guess the screen was plugged up and wasn't letting any water get to the pump.
Charles & Annette
1995 31' Excella
2001 Bambi Black Water Tank winethief 1997 - 2004 Bambi 12 06-10-2022 03:44 PM
HELP!! Mice in my 34' 2001 Excella jim.bailey@e General Repair Forum 20 05-31-2008 11:16 AM
34' Excella Water filter location JHD Water Heaters, Filters & Pumps 8 11-08-2007 03:34 PM
34' Excella for sale LadyExcella Link Archive 0 07-17-2003 12:21 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
