Old 04-17-2009, 08:23 AM   #15
Dan@LED4RV's Avatar
Denton , North Carolina
Whatever happened Jim. What did you find?
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-19-2009, 01:28 PM   #16
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
I am having the same problem. When I turn on the water, the pump comes on and pumps a small amount of water strongly and then it goes to a trickle. Do you have to have a pressure regulator in the water system?
What would happen if I removed the regulator from the system?
Charles
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 04-19-2009, 02:37 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
Charles
The regulator is only on the city water source side and has no effect on the pump. The reason you are seeing large swings in the water volume is the pump can provide more water than you are drawing at that point in time and thus shuts itself off. It will not come on again until the pressure switch in the pump calls for it to come on.
One way to reduce this is to install a small accumulator tank. These tanks have a bladder inside and you can pressurize one side of the bladder with air. By varying the air pressure you can reduce the frequency of pump cycles to fit you life style.
The tank can be installed anywhere in the cold water system down stream of the pump.
If you install an accumulator you should cycle the pump by the switch several times while drawing off the antifreeze when you dewinterize. This insures you purge the accumulator of antifreeze and wont taste it later.
2004 Excursion 4x4
Old 04-23-2009, 04:30 AM   #18
1995 30' Excella
Logan , New Mexico
Thanks HowieE,
I got my water problem figured out. There must be a screen on the hose that is inside the fresh water tank (FWT). I took an air tank and blew air into the FWT and now I am getting plendy of water when the water pump is engaged. I guess the screen was plugged up and wasn't letting any water get to the pump.
Charles & Annette
1995 31' Excella
HELP!! Mice in my 34' 2001 Excella Jim Bailey General Repair Forum 20 05-31-2008 11:16 AM
34' Excella Water filter location JHD Water Heaters, Filters & Pumps 8 11-08-2007 03:34 PM
2001 Bambi Black Water Tank winethief 1997 - 2004 Bambi 4 10-22-2006 07:03 AM
34' Excella for sale LadyExcella Link Archive 0 07-17-2003 12:21 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
