Old 01-11-2008, 07:01 AM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Water Pressure
After experiencing fluctuating water flow at a CG recently, I have ordered a water pressure gauge/regulator. What pressure range is safe when hooked to city water?
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 01-11-2008, 07:18 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Most RV water regulators are set around 45 PSI.
Richard
Old 01-11-2008, 08:29 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Tom
I've seen water pressure regulators anywhere from 40-60PSI. The adjustable ones with the guage let you know exactly where you are at. Remember to put the regulator at the spigot...before your hose leading into the trailer. This way, it not only protects your trailer plumbing....but the hose also.
Old 01-11-2008, 10:03 AM   #4
Cyclist
henw's Avatar
Sounds great. Thank you.
Tom
2007 28' Int CCD.
Two big screens
Centramatics.
Old 01-11-2008, 10:57 AM   #5
_
these modern a/s units are tested up to 90 psi?
and operational at 60 psi.
i agree IF you are gonna use a second reg, install pre hose.
the problem with using 2 regulators is that they can sometimes compete...
resulting in REALLY choppy, water-hammer like flow.
i tried two and couldn't get any smooth flow, with a short hose, and no filter.
the simplest way (4me) to reduce fresh water forces into the trailer is with a cartridge filter outside and a narrower gauge hose...
then IF there is a need for higher flow, just flip on the pump and cycle the tank water.
cheers
2air'
Old 01-11-2008, 06:07 PM   #6
jasper2222's Avatar
1996 25' Excella
Tallahassee , Florida
using pump and shore water at same time
Question,
Does it hurt to run the pump for additional pressure when hooked up to regular shore tap water. Book says not to, but I see no problems.
thanks, richard
jasper2222 is offline   Reply With Quote
Old 01-11-2008, 08:10 PM   #7
Kajtek1's Avatar
1965 22' Safari
Orinda , California
What would be the problem about getting water pressure from 2 sources? I had it done lot of times, as well as using the pump to boost the gravity pressure in Mexico.
Some high-end coaches have water supply going thru the tank/pump only. This way they always have the same pressure.
Kajtek1 is offline   Reply With Quote
Old 01-11-2008, 09:29 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Don't newer Airstreams have a built-in water pressure reducer? (And if I'm right, does anyone know when AS started doing this?) I used to use one at the faucet with our previousl SOB motorhome, and I've tried it a few times with the AS but it felt like it reduced the water pressure too much.
TB
TB & Greg and Abbey Schnauzer
#3954
Old 01-11-2008, 09:31 PM   #9
lewster's Avatar
RIGHT!
Most Prevost, Newell and a few other high-end MoHos do not use a city water inlet feed directly into the coach. They have an auto-fill valve on the city inlet that fills the on-board water tank. All water in the coach then comes from the coach's pump.....result is constant, consitent water pressure.
Old 01-11-2008, 10:27 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The built-in regulator on my '77 Excella 500 had 45 psi stamped on the tag hanging on it. I have been using an adjustable Watts regulator and have set it on 55 psi. I figure if the built-in regulator in my '86 fails or is set at 45 psi or higher then I am still safe.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-11-2008, 11:54 PM   #11
Kajtek1's Avatar
1965 22' Safari
Orinda , California
My 1965 Safari has build in pressure regulator. I just tried it after about 25 years of non-operation. It is slowing down the pressure raise, but allows it go all the way up to the city pressure.
Can't keep everything original on 43 years old coach
Old 01-12-2008, 10:16 AM   #12
davidz71's Avatar
1986 25' Sovereign
I have heard of people who connect their water pressure regulator at the campground and when they find that the pressure is within an acceptable range, they pull the regulator off. That doesn't make sense to me because pressure in the line when checked may be low and later may be higher than you want it. If the built-in regulator is not working correctly and pressure rises then this is a recipe for a rather wet trailer. I connect the regulator straight off the spigot and leave it there. When I know that I will be away from the trailer for a period of time I also shut the water off at the spigot just in case.
Craig
AIR #0078
3.73 rear end
Old 01-12-2008, 12:53 PM   #13
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Those RV-style in line regulators are garbage. I used them years ago and the pressure was never right. Putting them at the faucet with long garden hose helped, since the hose worked as a pressure accumulator, but that was just partial help.
Airstream is having copper plumbing, so has my vintage motorhome. At my residence city pressure is 120 psi, raising on the weekends to 150 psi. I have no problem running mine RV directly on that pressure, what makes for very good showers. The only occasional problem is, that water heater safety valve opens at 150 psi.
So I am using pressure regulators, but they are household regulators and I like them set to 80 psi.
Old 01-12-2008, 01:10 PM   #14
ScottW's Avatar
Hernando , Mississippi
Originally Posted by jasper2222
Question,
thanks, richard
Depends on which year model you are talking about. the newer ones (2006 on) state that you may use the internal pump and water to augment city water pressure.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 01-15-2008, 10:57 AM   #15
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
Water pipes
I have begun replacing my hot water heater and I need to hook up the water lines. regulator in a different way. How do you remove the crimped on clamps at the connections. I tried using channel locks to try and work them apart, but to no avail. Is there a special tool that removes these clamps?
I would appreciate any help that you all can give a frustrated newbie?
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 01-16-2008, 07:24 AM   #16
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Reganzo, The crimp connections should be cut out and replace the entire fitting. I would recommend the shark bite fittings or a similar brand. They will work on Polly pipe, Pex, cpvc and copper! They allow for rotation after they are pushed together and they can be taken apart and put back. Be sure and camphor or bevel the ends so the "o" rings are not damaged. Phil
Phil Gobie is offline   Reply With Quote
Old 01-16-2008, 10:10 AM   #17
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I bought one of those in-line pressure regulators, but stopped using it when I read that my unit has a regulator built in. When I had both in the water line, the pressure inside the trailer was so low it took minutes to fill the coffee pot, and we had to use the pump to supplement the pressure (my pump's manual says you can do that). Without the extra outside regulator, we have good flow and no issues.
Randy
Randy and Pat Godfrey
Florida Airstream Club (027)
WBAC# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 01-16-2008, 10:42 PM   #18
davidz71's Avatar
1986 25' Sovereign
Randy
Nothing work 100% of the time. If your onboard regulator fails then hope your lines hold should campground pressure be high.
Craig
AIR #0078
3.73 rear end
Old 01-16-2008, 10:46 PM   #19
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Blow out.
My regulator had a blow out.I posted up some pics and it seems it can hold a lot of pressure to a point.My AirStream is a 2005
Water hose connector
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 01-16-2008, 11:16 PM   #20
Kajtek1's Avatar
1965 22' Safari
Orinda , California
During restoration I had my full city pressure go to the trailer (due the faulty regulator) The copper plumbing with few hoses holds 150 psi just fine, but I didn't let it to be for long.
Not bad for 43 years old plumbing.
Even original water pump works after forced priming. It drips a bit, but I already ordered new check valves. The new replacement retails at $450.
If I can keep it running for $ 60 it might be worth it.
Water Pressure tsunami Sinks, Showers & Toilets 2 04-30-2007 06:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 01:07 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 05:45 PM
No water pressure gmlcjb Fresh Water Systems 9 12-29-2003 05:09 AM
