Old 01-15-2008, 09:57 AM   #15
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
Water pipes
I have begun replacing my hot water heater and I need to hook up the water lines. regulator in a different way. How do you remove the crimped on clamps at the connections. I tried using channel locks to try and work them apart, but to no avail. Is there a special tool that removes these clamps?
I would appreciate any help that you all can give a frustrated newbie?
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 01-16-2008, 06:24 AM   #16
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Reganzo, The crimp connections should be cut out and replace the entire fitting. I would recommend the shark bite fittings or a similar brand. They will work on Polly pipe, Pex, cpvc and copper! They allow for rotation after they are pushed together and they can be taken apart and put back. Be sure and camphor or bevel the ends so the "o" rings are not damaged. Phil
Phil Gobie is offline   Reply With Quote
Old 01-16-2008, 09:10 AM   #17
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I bought one of those in-line pressure regulators, but stopped using it when I read that my unit has a regulator built in. When I had both in the water line, the pressure inside the trailer was so low it took minutes to fill the coffee pot, and we had to use the pump to supplement the pressure (my pump's manual says you can do that). Without the extra outside regulator, we have good flow and no issues.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 01-16-2008, 09:42 PM   #18
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Randy
Nothing work 100% of the time. If your onboard regulator fails then hope your lines hold should campground pressure be high.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-16-2008, 09:46 PM   #19
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Blow out.
My regulator had a blow out.I posted up some pics and it seems it can hold a lot of pressure to a point.My AirStream is a 2005
Water hose connector
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 01-16-2008, 10:16 PM   #20
Kajtek1's Avatar
1965 22' Safari
Orinda , California
During restoration I had my full city pressure go to the trailer (due the faulty regulator) The copper plumbing with few hoses holds 150 psi just fine, but I didn't let it to be for long.
Not bad for 43 years old plumbing.
Even original water pump works after forced priming. It drips a bit, but I already ordered new check valves. The new replacement retails at $450.
If I can keep it running for $ 60 it might be worth it.
Kajtek1 is offline   Reply With Quote
Water Pressure tsunami Sinks, Showers & Toilets 2 04-30-2007 05:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 12:07 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
No water pressure gmlcjb Fresh Water Systems 9 12-29-2003 04:09 AM
