Old 03-29-2015, 07:34 PM   #1
1969 29' Ambassador
Hartselle , Alabama
Water lines 1969 Ambassador
Is there any way to cut out the ruptured parts of the water line and use off the shelf repair connections? The water lines seem to be a different size?
dave69 is offline   Reply With Quote
Old 03-29-2015, 08:29 PM   #2
1974 Argosy 20
Kooskia , Idaho
In general, assuming you have copper pipes in your '69, they have frozen and expanded until they were too thin to hold, then they ruptured. Once they have expanded, they seem like a different size pipe and no new fittings will fit on the old pipe. Lots of people try to hold them together with rubber hose and clamps, but in the long run you will be much better off replacing the plumbing with new PEX lines.
Sorry to be the bringer of bad news, but the only real solution, unless you have a minor leak only is to replace the plumbing. If you try to patch it up, you will be patching and patching and patching.
Old 03-29-2015, 08:40 PM   #3
1969 29' Ambassador
Hartselle , Alabama
I was afraid of that. I've redone a couple of other airstreams and was hoping for a short cut.
plumbing lines in '71 ambassador bimi Fresh Water Systems 11 05-22-2017 04:23 AM
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 09:51 AM
Were is the Water Pump? 1969 Ambassador Silverflames 1966 - 1969 Ambassador 4 06-07-2012 03:50 PM
Noisy water lines when using fresh water tank Castaway Fresh Water Systems 14 12-17-2010 03:01 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
