04-17-2006, 09:26 AM
1975 31' Sovereign
Oxford
, Mississippi
Water line leaks
We are looking into having our trailer totaly re-done with pex. How much do you think it would take for a 31 ft center bath and also how many hours to do. We would like to find a plumber to do it here in our home town.
Thanks for any advice,
Becky
04-17-2006, 10:07 AM
San Angelo
Becky,
Ron at South Jersey RV redid our 31ft rear bath, and this is what it took:
about 50ft of Pex,
about $150 for fittings and crimps
about $.40/ft for the Pex
and about 12-16 hours to do the whole job.
Good luck.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
04-17-2006, 01:14 PM
1975 31' Sovereign
Oxford
, Mississippi
Frederic,
Thanks so much for the info. I would love to be able to do what you did to your trailer it looks so nice with the total re-do.
Becky
04-18-2006, 07:58 AM
San Angelo
Becky,
Thank you for the kind words. The trailer is back at the shop getting its shakedown problems repaired, but I am very happy with the outcome....it looks like it would have in 1971....sort of, which was my goal. I just couldn't bring myself to do shag...maybe next time.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
04-20-2006, 12:06 AM
Colville
Assuming a do-it-yourselfer (read: cheap,poor) were to replace all the plumbing is it going to be cheaper to do pex, or stick with copper? I've got multiple freeze bursts in the lines (copper) leading to the front sink. So far haven't seen any obvious holes in the rear plumbing, but I'm assuming there's probably more - best case scenario is that I only have to replace the lines leading to the front, but worst case is the entire shebang. I haven't yet tested the plumbing since I've currently got the sink detached. I just hope the water heater hasn't froze and cracked!
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
04-20-2006, 02:30 PM
San Angelo
From what I see, Pex is the way to go. I've messed with copper, and I'm no plumber. 3-year olds color better than I flux and solder, LOL. I would rather fit and crimp anyday.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
04-21-2006, 09:56 AM
Frank S
peoria
How about PVC white plastic, which can be glued together. It is easy to work with, and more cost effective than PEX, or copper.--Frank S
04-21-2006, 04:39 PM
1964 26' Overlander
Norman
, Oklahoma
PVC pipe is not approved for use with hot water, you would have to use CPVC which is also a glue together pipe requiring a special glue. The problem with this type of piping is how brittle it is when used in a travel trailer. PEX is really the way to go if you are planing to re-pipe. You will pay a little more in the beginning, but you will end up with a first rate water system that will give you few problems.
Mark
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
04-22-2006, 10:07 AM
San Angelo
Plus, PEX won't burst, like PVC or CPVC. I believe my PEX is rated to 120psi.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
04-22-2006, 01:57 PM
2003 22' International CCD
Kiln
, Mississippi
Smaller diameter PVC and CPVC (1/2 inch or 3/8 inch) is rated in excess of 1000psi so bursting would not be an issue. The special glue costs no more than the glue for regular PVC (white kind). In the amounts you would buy it's only a couple of dollars. With either types, joint prep is a must. Rough up the ends and fittings with sand paper or use the pipe cleaner (purple stuff) to prep the ends before the application of the glue then hold the joint tight for 30 sec to allow time for the glue to set and weld the joint together.
It's the non-flexability of the PVC that's an issue. Constant vibration can cause small cracks and then eventual failure of the pipe and even the glue joints if they are not set properly. PVC is not ideal for locations where alot of movement is allowed. Working in tight spaces with the glue and solovents is bad for you. Be sure to have alot of ventilation. I like the copper in my Caravel but will admit, PEX is what I will use during the rebuild, with maybe the long runs in copper.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
04-23-2006, 06:41 AM
San Angelo
Michael,
Thanks for the clarification. I hope I never run into the campground that has 1000psi water pressure!
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
04-23-2006, 07:45 AM
Airstream - Other
Bosque Farms
, New Mexico
We're sticking with copper, at least for the time being! Sure, it's bad for freezes. When we dewinterized just yesterday, we had a geyser under the back closet floor. However, an hour or so later, and the whole thing was fixed. (Next time, we'll not only blow out the water, but also add the antifreeze.)
Lynn
ACI Big Red Number 21043
04-25-2006, 12:43 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
I thought I was goin' campin'
Just watered my 76 Argosy20 getting ready for a weekend at the beach. Turned on the pump to find no flow at any faucet...but planty of water coming through the bottom skin aft. OMG! Took off the aft skin piece for nice view of weaste system, but the water is supply side and I suppose above the plywood. Most likely under shower. No water visible topside in the bathroom.
Do I have to take out the fixtures to get to water lines? What is the sequence so as to do as little damage as possible? (I am the proverbial bull in the china closet.)
Needing words of encouragement...
Nick
Happy when I'm rollin',
Nick
WBCCI#3528
04-25-2006, 08:42 PM
1975 31' Sovereign
Oxford
, Mississippi
Nick,
We are pretty new to all the plumbing, but I think you need to check the pipes inside to see if you see where the water leak is.
Becky
04-28-2006, 02:01 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
Thanks for the encouragement, Becky.
Took the advice and found frost breaks in Galley water supply in front of black water tank and side of shower tray.
Currently stymied to find repair materials for "odd-sized" copper pipe/ tubing. Bigger than 1/2, smaller than 5/8. Local plumbing supply mystified. Any clues. Hoping to repair well rather than cob it or re-plumb.
Any suggestions gratefully accepted.
best,
Nick
Nick
WBCCI#3528
04-28-2006, 08:21 PM
1975 31' Sovereign
Oxford
, Mississippi
My husband is not a plumber and I'm not I think we are going to hire (try to find one) that will take on the job of re-doing the whole trailer with pex and just dis-connect all copper. We are lucky we are camping at all local campgrounds with clean restrooms so at this time we don't use the water until we get it re-done. Sorry not much help.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
