Old 09-08-2007, 08:44 AM   #1
Water line blockage
I flush my hot water tank yearly on my 28' CCD. This time the calcium clogged some of my water lines. Just a trickle at the sink, both hot and cold water, and the shower. I've taken the lines apart under the sink, ran a thin wire through the sink sprayer, and still no running water. Any advice out there?
robtan is offline   Reply With Quote
Old 09-08-2007, 08:53 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
replace or clean your aerators on your faucets.
i keep a ziplock baggie of them in my junk drawer for just such an occurance.
john
you call them ferrets, i call them weasels.
Old 09-08-2007, 09:14 AM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Robtan,
White vinegar will dissolve the calcium, (actually most likely lime) and return things to operate like new. Take the offending part, ie shower head, faucet aereator, etc. and put them in as small a container as you can and be able to completely cover the item with vinegar. Let them soak for 24 hours, take and rinse thoroughly. If it isn't clean, repeat, then reassemble and be happy!
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 09-08-2007, 09:16 AM   #4
wascobob's Avatar
wasco , Oregon
robtan----Another place you might want to check is on the upstream side of the screen that is between the water tank and the pump. On mine, the screen was clean but the hose on the tank side of the screen was clogged with plastic cuttings from the manufacturing process; cleaned it out and have had great water flow from then on.........
-------Cheers--Bob
1988 Classic 290 motorhome
wascobob is offline   Reply With Quote
Old 09-08-2007, 09:57 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Last year I found barely a trickle from my kitchen and bathroom sinks. I flush out the hot water tank twice a year and did the normal clean out the faucet screens but this did not help. Over a period of time calcium had been building up in the bypass line attached to the lower cold water inlet on the water heater and it had backed up some 3 inches into the hose. I assume flushing out the tank also played part in this so I must remember to turn the water on to flush any that might go back into this area. Anyway, I had to take the mattress off and unscrew the wood top in order to get to these hoses with a wrench. I used a coat hanger on the flexible lower hose which I could not even blow through. That took care of the problem. I have since simplified getting to this area by adding new wood and a screw-on boat deck lid. Hope this helps.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-08-2007, 09:59 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Your check valve that is connected to the HW tank may also be clogged. They don't clean very well, so I would replace it with a new, solid brass model from Camco. They have the only all-metal unit for RV use.
Old 09-08-2007, 11:18 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Those denture cleaning tablets work good also. You can throw a couple in your toilet water closets at home too
PS They go all fizzy and are also more fun to watch than vinegar.
Water Line Damage, What Can I Do? elliottkatz Fresh Water Systems 6 06-24-2007 10:48 AM
Water Line Route skippervido Fresh Water Systems 2 04-24-2007 11:25 PM
Water line leaks rebel beck Fresh Water Systems 15 04-28-2006 08:21 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
water line leak Bugsy1082002 Plumbing - Systems & Fixtures 5 10-30-2002 07:27 AM
