Old 02-14-2008, 02:40 AM   #1
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
Water level Sensor removal/cleaning/replacement
My manual explains how to test the leads from the sensors to see if the rest of the system works, and it does. Then it says to unscrew the sensors from the tank and clean them - this is where I'm stuck. I can unscrew the leads from the sensors, but the sensors don't look like the diagram in my manual. Are these removable? If so, how do you remove them? I tried some needle nose pliers on the slight nobs next to the terminals, but the plastic is so soft it wasn't doing anything. Thanks in advance! -Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 02-14-2008, 04:52 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Kevin,
It looks to me like your "sensors" are just the tips of the screws protruding into the tank and contacting the water. That's the way my 1970 Caravel works.
On later models, the "sensors" are threaded black plastic inserts that are screwed into 1/2" fittings in the tank. These inserts/sensors have a metal core that is, in turn, threaded to accept the screw that holds the wire and on the other end protrudes into the tank. You can take out the screw that holds the wire from these without causing a leak. In either case, these "sensors" are just conductive metal that provide a path through the wall of the tank to the water.
Zep
Old 02-14-2008, 02:39 PM   #3
1996 28' Excella
Portland , Oregon
that could be easy!
Thanks for the reply Zep!
Well, I'm going to have to check more now. I did take the leads off the sensors to do my testing, and the screws are only about 1/4 inch long and I think they are brass. They screw into some sort of metal thread...but the tank is empty, so I don't know if they are indeed the actual sensor touching water. More pictures and investigations to come.
BTW, I was trying to do more searching on the subject, and amazingly enough, my grey and black water sensors work perfectly! Although I'd give up both for the freshwater sensors to work.
-Kevin
Level Sensor - Black water holding tank. mharrison@ie Waste Systems, Tanks & Totes 3 12-31-2007 06:09 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
new water pump - Jabsco sensor max 14 adonh Water Heaters, Filters & Pumps 2 11-15-2007 02:54 PM
Water tank Sensor locations..... leefields Plumbing - Systems & Fixtures 1 02-17-2006 11:16 AM
Don't forget: Check your battery water level.... Safari Tim Batteries, Univolts, Converters & Inverters 2 11-14-2004 12:30 PM
