Old 03-04-2012, 09:19 AM   #1
eek
2004 25' Safari
Keno , Oregon
Water leaking
I have a 04 safari and I seem to have a leak problem where you conect the water hose for the city water inlet. I pulled the out side cover off once and tighted it up but now it seem to be leaking again( filled the rear belly pan with water and that came crashing off but that has been fixed) do I need to put new gaskets in here its not all that easy to get to.
Thanks for any advice eek
eek is offline   Reply With Quote
Old 03-05-2012, 08:58 AM   #2
Johnco's Avatar
2006 19' Safari
Anaheim , California
Not sure about the 2004, but on my 2006 the city water inlet has a built-in pressure regulator that will crack and leak. Just replace the whole assembly, they are available at CW for around $30.00.
Johnco is offline   Reply With Quote
Old 03-05-2012, 09:03 AM   #3
eek
2004 25' Safari
Keno , Oregon
Thanks Ill check it.
Old 03-05-2012, 12:25 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
eek,
Check the connection first.
... make sure there is a good gasket inside the hose fitting.
Then hold the "star" securely as you tighten it against the supply hose.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-05-2012, 03:15 PM   #5
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
happened to our 2010 1yr in. had the dealer replace and no trace.
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
Old 03-06-2012, 06:36 AM   #6
eek
2004 25' Safari
Keno , Oregon
Its on the inside I have tighted it before and it seemed to have fixed the problem but it has started leaking again.
Old 03-06-2012, 09:30 AM   #7
dsrtgrls's Avatar
Clarkdale , Arizona
Smile
yep. wet fiberglass insulation on the inside,saw it drip particularly when running shower. replaced. no leak since.
"Open paddock 9!"
Old 03-06-2012, 10:08 AM   #8
2000 25' Excella
Northern , California
I don't know the make-up of the fittings inside, but since you mentioned that you've tightened it with at least temporary success, I gather that it is a hose connection. For what it's worth, in my experience, the hose fittings and their washers are prone to damage from the constant on-off, or from "tightening", and a resultant pooching or gathering. I've found that the application of a silicone lube, such as "Magic Lube" or a similar product sold at Leslies Pool Supply called "Pool and Spa Lubricant" does a great job of facilitating a seal, and also lubricating the gasket to prevent the gathering and pooching, allowing better tightening, thus far fewer hose connection leaks. I also use it an pipe fittings, after the teflon tape, or on any "O"-rings. I keep a tube in my AS toolbox.
Kamiak is offline   Reply With Quote
Healthy/Green Fresh water storage tank SteelyDan Classic Motorhomes 23 03-27-2012 08:55 PM
New low tech water heater Globie64 Water Heaters, Filters & Pumps 17 03-05-2012 10:23 AM
Bowen G6A2 water heater refurbishment dryenko Water Heaters, Filters & Pumps 0 02-29-2012 05:10 AM
High Flow Water Pump - yes / no ? MrJ Mechanics Corner - Engines, Transmission & More... 7 02-28-2012 11:07 PM
Tankless water heater tlynn87 1974 - 1979 Sovereign 8 02-28-2012 09:04 AM
