07-18-2019, 11:51 PM
2018 22' Sport
San pablo
Water leak .. newbie
I m connected to a city water and i observed there is leak in the small black screened opening in the fresh water tank. I want to use the city water instead of filling the freshwater tank. Help.
07-19-2019, 12:04 AM
2007 22' International CCD
Corona
That means your water pump has a check valve issue. Run the pump open a faucet for a minute, and shut it off several times. Wait for the pump to stop, and do this again a few times.
That might clear the internal debris that’s keeping the check valve from seating.
Search the forums for more on the subject.
07-19-2019, 03:13 AM
Sag Harbor
, New York
Welcome to the forum!
To add detail to Rich's advice, here are some search results to check out:
https://www.google.com/search?q=pump...com&gws_rd=ssl
What happens is that, as the city water fills and pressurizes all your hot and cold water lines, this pressurized water is leaking "backwards" through the pump's check valve, going into your water tank, and then out the over-flow tube.
Hopefully the check valve will re-seat itself as Rich suggested. When you run the pump, using your full water tank, you may have to open every faucet [both H/C] to get air out of the system, and to enable the pump to be primed correctly.
Your owner's manual should help you find the pump, and its pre-filter for the water coming from the water tank. Be sure to remove and clean out this filter.
When using city water, and filling your water tank, you should always use a filter like this one at the hose bib:
https://www.amazon.com/Camco-TastePU...gateway&sr=8-3
Grit in the water can get stuck in the pump's check valve, as well as in all your faucets and aerator filters at the faucet spigots -- NG.
Good luck,
Peter
2018 22' Sport
San pablo
I have turnes the pump on discounted the xiry watn the hustbemp umtied the watee with punp on. So now if i connext mt city water, it wornt leak in the fresh watwe tNk?
07-19-2019, 03:16 AM
2018 22' Sport
San pablo
Can i just rn the aierstrean through city water and shut iff the fresh water tank
07-19-2019, 03:23 AM
Sag Harbor
, New York
Yes, you can use only city water, but see my earlier post to make sure you have all your bases covered. There will be water in the tank, which you have to make sure stays clean and sanitary, but that is another topic.
Also it will help everyone if you can Edit your posts to clean up the spelling a little IMO [see Post #4 ]
Peter
PS -- Going to work will be back later, good luck.
07-19-2019, 06:50 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
Turn your WATER MAKER off.....
Here is the OP’s first thread with same question.
http://www.airforums.com/forums/f368...ie-198344.html
07-19-2019, 07:03 AM
Sag Harbor
, New York
Thanks.
It might be easier if you stick to this thread IMO.
Cheers,
Peter
07-19-2019, 07:44 AM
Overland Adventurer
2009 34' Panamerica
Telluride
I take the pump apart every year to clean it out. Despite great effort to pre filter all incoming water, something always finds its way to the pump causing a backflow and a leak back into the tank. I've never had to replace the bump due to this issue. Good luck!
07-19-2019, 06:48 PM
2000 27' Safari
Schaumburg
water leak
to Peter
I thought your explanation of the check valve was very good. After owning my Safari for 21 years, I thought in ew most everything about it. I now know that I don't. When II winterize my trailer this year, I will be looking for that check valve.
Thanks for the info
Pressdr
07-19-2019, 09:33 PM
2017 30' International
Broomfield
As rmkrum mentioned above the check value in the pump is not working.
$100 bucks replace the pump.
Clean the old one out and keep it as a spare.
I have a spare pump on board and I have had to do a field swap in the past. The surflow pumps aren’t what they used to be......
07-26-2019, 10:50 AM
2010 20' Flying Cloud
Roanoke
It looks to me like you are filling the fresh water tank. The city water fill should be on the side near your electric.
07-26-2019, 05:05 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
No, they are hooked up to city water but the fresh tank is being filled because the check valve in the pump is stuck open and allowing water to backfill through the pump in to the tank. Read through this thread for more info, it's a good thing to understand, as it might well happen for you down the road.
07-26-2019, 05:56 PM
1968 26' Overlander
CORDOVA
, TN
On my Overlander there is a valve to close off manually that will prevent water from backing up to the fresh water Tank? Are the new ones not like that? Its simple to close it off?
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
07-26-2019, 07:00 PM
The Aluminum Tent 3
Park City
, Utah
Not on later models. The backflow prevention is via a check valve built in to the water pump. That valve gets clogged and stuck open.
Reading about this problem over and over again. I think I am going to add a shutoff valve in front of or behind my pump though. One more thing to remember to open or close depending on if I'm on City or Fresh Tank, but a worthwhile modification now that I think about it. I like options.
07-27-2019, 07:39 AM
1968 26' Overlander
CORDOVA
, TN
Wow...I guess they did that to make the process more "automatic"......interesting....I can see several disadvantages to not having a shutoff for the freshwater tank, but only one advantage to not having it, which is the automatic switchover....aside from the fact that if you do not have another valve up there, then it cannot leak ! ......
07-31-2019, 09:29 AM
Arroyo Grande
That is your fresh water tank overflow opening. If you are connected to city water and you are getting water out of that opening, there is a good probability that the check valve at your pump is not working and you are back-filing your fresh water tank. R
07-31-2019, 05:37 PM
2019 27' Globetrotter
Litchfield Park
His check valve has failed, the fresh water tank is full, and with city water hooked up water is coming out the fresh water inlet and air vent since water is still going in the fresh water tank because of the failed check valve.
So the OP can't use "only city water" until he fixes the check valve problem. A 2018 should still be under warranty so I'd take it to the nearest dealer and get the water pump replaced rather than take the pump apart to clean it, etc. and probably void your warranty.
I'm on my third water pump in a 2019 because of faulty check valves. I wonder if Shurflo now makes their stuff in China like everything else. Damn shame. Their products used to be pretty good.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
08-04-2019, 02:45 PM
Sag Harbor
, New York
Yes, Steve, that is why I also said in Post #6:
Yes, you can use only city water, but see my earlier post to make sure you have all your bases covered. [emphasis added]
You dropped the bold text above when you just quoted me.
That "earlier post" [#3] assumed that he would be able to re-seat his check valve per the advice of rmkrum.
Peter
