Old 07-18-2019, 11:51 PM   #1
2018 22' Sport
San pablo , California
Water leak .. newbie
I m connected to a city water and i observed there is leak in the small black screened opening in the fresh water tank. I want to use the city water instead of filling the freshwater tank. Help.
ID:	347034   Click image for larger version
Clarque2003 is offline   Reply With Quote
Old 07-19-2019, 12:04 AM   #2
2007 22' International CCD
That means your water pump has a check valve issue. Run the pump open a faucet for a minute, and shut it off several times. Wait for the pump to stop, and do this again a few times.
That might clear the internal debris thatís keeping the check valve from seating.
Search the forums for more on the subject.
Old 07-19-2019, 03:13 AM   #3
Long Island , New York
Welcome to the forum!
To add detail to Rich's advice, here are some search results to check out:
https://www.google.com/search?q=pump...com&gws_rd=ssl
What happens is that, as the city water fills and pressurizes all your hot and cold water lines, this pressurized water is leaking "backwards" through the pump's check valve, going into your water tank, and then out the over-flow tube.
Hopefully the check valve will re-seat itself as Rich suggested. When you run the pump, using your full water tank, you may have to open every faucet [both H/C] to get air out of the system, and to enable the pump to be primed correctly.
Your owner's manual should help you find the pump, and its pre-filter for the water coming from the water tank. Be sure to remove and clean out this filter.
When using city water, and filling your water tank, you should always use a filter like this one at the hose bib:
https://www.amazon.com/Camco-TastePU...gateway&sr=8-3
Grit in the water can get stuck in the pump's check valve, as well as in all your faucets and aerator filters at the faucet spigots -- NG.
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 07-19-2019, 03:13 AM   #4
2018 22' Sport
I have turnes the pump on discounted the xiry watn the hustbemp umtied the watee with punp on. So now if i connext mt city water, it wornt leak in the fresh watwe tNk?
Old 07-19-2019, 03:16 AM   #5
2018 22' Sport
Can i just rn the aierstrean through city water and shut iff the fresh water tank
Old 07-19-2019, 03:23 AM   #6
Yes, you can use only city water, but see my earlier post to make sure you have all your bases covered. There will be water in the tank, which you have to make sure stays clean and sanitary, but that is another topic.
Also it will help everyone if you can Edit your posts to clean up the spelling a little IMO [see Post #4 ]
Peter
PS -- Going to work will be back later, good luck.
Old 07-19-2019, 06:50 AM   #7
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Turn your WATER MAKER off.....
Here is the OP’s first thread with same question.
http://www.airforums.com/forums/f368...ie-198344.html
Dept of ďOverKillĒ
Old 07-19-2019, 07:03 AM   #8
Thanks.
It might be easier if you stick to this thread IMO.
Cheers,
Peter
Old 07-19-2019, 07:44 AM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I take the pump apart every year to clean it out. Despite great effort to pre filter all incoming water, something always finds its way to the pump causing a backflow and a leak back into the tank. I've never had to replace the bump due to this issue. Good luck!
Old 07-19-2019, 06:48 PM   #10
2000 27' Safari
Schaumburg , Illinois
water leak
to Peter
I thought your explanation of the check valve was very good. After owning my Safari for 21 years, I thought in ew most everything about it. I now know that I don't. When II winterize my trailer this year, I will be looking for that check valve.
Thanks for the info
Pressdr
Pressdr is offline   Reply With Quote
Old 07-19-2019, 09:33 PM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
As rmkrum mentioned above the check value in the pump is not working.
$100 bucks replace the pump.
Clean the old one out and keep it as a spare.
I have a spare pump on board and I have had to do a field swap in the past. The surflow pumps arenít what they used to be......
wulfraat is offline   Reply With Quote
Old 07-26-2019, 10:50 AM   #12
2010 20' Flying Cloud
Roanoke , Virginia
It looks to me like you are filling the fresh water tank. The city water fill should be on the side near your electric.
Rovin Raven is offline   Reply With Quote
Old 07-26-2019, 05:05 PM   #13
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
No, they are hooked up to city water but the fresh tank is being filled because the check valve in the pump is stuck open and allowing water to backfill through the pump in to the tank. Read through this thread for more info, it's a good thing to understand, as it might well happen for you down the road.
pcskier is offline   Reply With Quote
Old 07-26-2019, 05:56 PM   #14
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
On my Overlander there is a valve to close off manually that will prevent water from backing up to the fresh water Tank? Are the new ones not like that? Its simple to close it off?
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Water leak .. newbie Clarque2003 Member Introductions 5 07-20-2019 08:58 AM
Newbie water pump/leak question rlhendren Water Heaters, Filters & Pumps 8 11-22-2016 03:36 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
