Old 09-20-2015, 03:05 PM   #1
1989 25' Excella
Newport , Oregon
water leak center bath
I have just replaced the floor from the wheels back on my 89 Excella, with center bath. Replaced most everything from the shower back. There were hot water tank leaks, fitting leaks, floor wrap leaks, tail light leaks, and others. I did not do any work under the sink area of the bath. Last thing I did was pressure up the water system via the pump left it on for 6 hours and no leaks. Then installed new cork floor moved on. Now we are on the road and have developed a severe leak on the bath room floor. Water comes out from under the sink on top of the floor. The wheel well is dry as are all the pipes that supple the sink. I believe I have narrowed it down to the three pipes that disappear through the floor below the shower controller. The shower is not used and the controller is not in the system any longer. I cannot figure out how to get to the bottom of the three pipes that go down through the floor. Does anyone have any ideas on how to get to this area?
sonoftol is offline   Reply With Quote
Moving rear bath to center split bath jrossingaul Plumbing - Systems & Fixtures 8 03-08-2013 12:03 AM
Center bath or rear bath Sovereign? desertratt General Repair Forum 9 09-24-2011 09:40 PM
want to trade center bath for rear bath? nomader General Repair Forum 7 02-23-2010 05:40 PM
Water Heater Replacement on a 75 center bath Wayne Gilley Water Heaters, Filters & Pumps 2 06-11-2006 10:11 AM
