Old 07-20-2004, 09:23 AM   #1
dikku@mac.com's Avatar
Unhappy water leak 92 Sovereign
Please Help!
We just purchased a 92 Sovereign 21 foot Airstream. My wife hooked up the water line with a hose and cleaned out the shower. She left the water hooked up all night. This morning I noticed that the floor adjacent to the shower was wet and there was a steady drip below this area on the underside of the trailer.
Does this indicate a burst pipe? We could hear a steady drip with the water attached and turned on, while we sat in the bathroom. This disappeared when we turned the water off.
dik
dikku@mac.com is offline   Reply With Quote
Old 07-20-2004, 09:38 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Sounds like a loose fitting more than a burst pipe. If the Pipe was burst the interior would be more like a swimming pool It could be a cracked fitting, the Grey pex is known for that.
Since the water is showing up in the bathroom, I would start with the fittings under the sink, they are the easiest to get to. Second would be the fittings on the rear of the toilet. These sometimes leak after an improper winterizing, or just from age. Last would be the backside of the shower fixture. I am not familiar with your trailer so I cannot offer a "how to" on getting to the back of the shower faucets.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-20-2004, 02:04 PM   #3
more info
I disconnected the supply hose with the pressure regulator and the drip stopped. I turned on the water pump and then the shower and no leak. I assume the leak must be in the plumbing in from the external water supply.
I am having trouble looking behind the toilet due to the confined space.
dik
Old 07-20-2004, 02:26 PM   #4
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
You would think so
But that is only really telling you that the leak shows when under full 45 PSI pressure. The pump cuts out at 30-35 PSI in most cases.
If you can get to where you can see the plumbing that comes in from the city water connection I would check it too. These water system leaks happen in the strangest places.
Brett G
water heater leak? mirwin Water Heaters, Filters & Pumps 5 06-03-2005 11:12 AM
Major fresh water tank leak! JohnGalt48 Fresh Water Systems 2 05-17-2004 05:50 PM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 10:32 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
