Old 05-09-2012, 09:15 PM   #1
1987 25' Sovereign
Rye , Colorado
water leak
Howdy!
I have a water line leak in our 1992 Land Yacht Motorhome 30'. Line broke under the bed. Silver pressure valve to 150 psi. I can send a picture if you want. Plumbing shop nor 2 RV stores had it. Said only at Airstream.
Also, there's a switch in the water line that might be a "winterization" switch. Anybody hear of it?
Thanks!
Guy
guyrichter is offline   Reply With Quote
Old 05-09-2012, 09:55 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
A winterizing switch may be a valve at the water heater to close it off from filling with antifreeze. As for 150 psi......wow......most are 40 - 50 psi.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-10-2012, 05:32 AM   #3
1987 25' Sovereign
Rye , Colorado
Can I send you a picture to your direct e-mail? Maybe you would recognize this deal. I'm familiar with the water heater bypass. WE had a 1987 Soveregn 25' with a lever in line. This coach has some sort of electric switch.
Thanks!
