Old 02-08-2012, 03:52 AM   #1
2007 25' International CCD
Alozaina , Malaga
Water Inlet Tube
2007 Airstream Continental 25.
The water inlet pipe will not undo, it simply spins around, its a sort of four cornered plastic thing. Am I missing something? Is there a knack? I have only connected it once as the Airstream has been static for some years and the first time I try to undo it, like I said it turns but dose'nt get free or undo.
Help appreciated.
watertalks is offline   Reply With Quote
Old 02-08-2012, 06:38 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Got a picture? Trying to visualize exactly what you're asking about.
Chris
Old 02-08-2012, 06:50 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You have to hold the hose from rotating when you rotate the square plastic thing, which is actually the nut to tighten the hose to the trailer interface.
Old 02-08-2012, 06:57 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
If this is IT, hold the inner and turn the outer.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 02-14-2012, 08:39 AM   #5
Alozaina , Malaga
Thats great thank you worked first time the thing that threw me was that the plastic thing with the four corners was spinning on the coupling.
The problem now is that the coupling is leaking badly from the back, thats the coupling attached to the Airstream and the one that turns. I assume this is a fairly regular and common problem but don't know how to move forward b ut need to do something as at present its useless. Any ideas please.
Old 02-14-2012, 08:57 AM   #6
1977 31' Sovereign
1989 34' Excella
Replace the rubber hose washer. Or put in one, if it is missing. The seal does not occur on the back side of the four corner tightening nut. There can not be a leak at that point. The seal occurs between the end of the male hose connector and the front surface of the inlet pipe going into the trailer.
Old 02-14-2012, 09:30 AM   #7
Thumbs up
WT,
As mentioned above...make sure the gasket is good.
Then reverse the process, hold the inner and tighten the outer, it won't seat properly if you don't hold it gud.
W. H. Auden
Amanamus
"Tahawus"
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Water Tank Inlet Cover BadKarma226 Fresh Water Systems 6 07-05-2011 02:38 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
Locating new city water inlet Globie64 Fresh Water Systems 12 03-10-2011 08:55 PM
Placement of new water inlet??? robwok Plumbing - Systems & Fixtures 14 03-02-2011 09:01 PM
