Old 05-29-2013, 11:30 PM   #1
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Water Inlet 1984 31ft Excella
It happened....I de-winterized the trailer, and the inlet housing is cracked. I guess there was some water there when I capped it.
Now I need a part, and so far no luck without totally changing the way this works.
Where do I get this housing?
Here is a pic:
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 05-30-2013, 12:05 AM   #2
1974 Argosy 20
Kooskia , Idaho
It is a common part, yours is probably gray poly plastic but it may be metal, can't tell from your photo. It is generally called a washing machine faucet mounting ear elbow. The hose part is also available. Home Depot or Lowe's. They are also available in Sharkbite fittings.
Old 05-30-2013, 01:47 AM   #3
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Thanks!
Thanks!
This might be easier than I thought it was going to be!
David
TAC # TX-18
AIR # 410
Old 06-06-2013, 11:30 AM   #4
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
The repair was easy. The damaged part was plastic. The new part is a Sharkbite brass fitting. Inside the trailer a pex compression elbow and pex compression union.
Good to go now!....The question is where to go?
David
TAC # TX-18
AIR # 410
Old 04-29-2014, 09:07 AM   #5
1987 29' Sovereign
Peyton , Colorado
I am having the same problem...Don't suppose that you remember the size of fittings you used do you?
murf259 is offline   Reply With Quote
