Old 05-21-2010, 09:32 AM   #1
1973 23' Safari
Smithfield , Virginia
Water in FW tank for two winters!
After buying and then storing my Ď73 Safari double LY for two winters, Iíve started getting it Road/Camp ready. Last evening I found the water tank drain and opened it. To my surprise and chagrin, a steady stream of water started to pour out of the drain. It was still draining when I went in for the evening.
My thought/question is, if the tank was damaged by freezing, wouldnít all the water have leaked out after it defrosted? So maybe the tank is not broken. My next thought is to fill the FW tank and look for any leakage coming from the bottom. No leaks equal no damage?
Another question I have. Is there an easy way to access the FW tank to inspect it? On the bottom of my unit is what looks like an access panel. I havenít tried to open it, mostly because there are gas lines in the way. Is this really a way into the bottom?
Any thoughts, comments?
jasmith58 is offline   Reply With Quote
Old 05-21-2010, 10:44 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Well, it's not just the water tank, but also the pump and the water lines I'd be concerned about. Were the water lines, pump, and water heater all empty for both winters?
The tank may have survived - it would depend on how much water was in the tank, and how cold it got over the winter. Just because the tank didn't leak that you could see, doesn't mean that a crack didn't develop along the top of it. I'd start with filling the tank completely, and then checking for leaks.
Yes, that big piece of plywood under the trailer is what holds the water tank in place. You can remove the plywood to get access to the water tank, but be aware that on your 23 foot trailer, you'll probably need to remove the front stabilizer jacks in order to completely remove the plywood panel. Plus, those panels do not slide out very easily. If you do decide to remove it completely, the tank will drop out of the bottom of the trailer, so be sure to disconnect all the plumbing lines that attach to the tank. Fortunately, they are all located in the same access hole inside the trailer where you probably found the drain valve.
I would suggest that you slide the plywood plate forward a couple of inches, and then fill the tank with water. Then if you have any leaks, you'll be able to see the water running out of the opening you created by sliding the panel forward a bit. If all stays dry, then you should be ok as far as the tank is concerned.
Oh, and be sure to sanitize the tank and water system before you use it!
Chris
2 years 2 winters in montana mtmagpie Winter Living 1 07-18-2010 02:11 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Medal of Honor for Maj. Winters azflycaster Off Topic Forum 3 11-10-2007 08:44 AM
