Old 07-11-2015, 08:08 PM   #1
1984 27' Sovereign
Nixa , Missouri
Water Hook-up Whoas
I have been searching the forum trying to figure out why water is coming out of one of the small gray pipes out the back. I have two valves and they are closed. The water just comes out the one, and it looks like there should be a valve on this one or a cap? I tried to attach a pic of what It looks like. I am a new Airstream owner of a 84 Sovereign and any advice or help I can get is greatly appreciated!
Kayme is offline   Reply With Quote
Old 07-11-2015, 09:16 PM   #2
Loafy the Wonder-Sled
Tumbleweed61's Avatar
1986 25' Sovereign
Mercury , Nevada
I'm afraid it's difficult to tell what's going on from your picture.
In our case, when we first got our '86 Sovereign, it leaked out the back when I fired up the water pump. This was due to a bad pressure regulator on the external water supply line (back leakage). I have since replaced said regulator with a valve (and use an external pressure regulator) until I install a new one.
"The sting of having paid too much remains long after the veneer of newness has worn away."
'86 Sovereign 25'. Somewhere near Mercury, NV
Tumbleweed61 is offline   Reply With Quote
Old 07-11-2015, 09:39 PM   #3
1979 23' Safari
Wayland , New York
What's upstream of where it comes out? Manual valve, being possible low point drain? Relief valve? Either could be bad.
Old 07-12-2015, 08:56 AM   #4
1984 27' Sovereign
Nixa , Missouri
It looks like there is only one pipe leading from the outside hookup to this point. There is no other arms or valves until after the small extension where the water starts to come out. I took another pic that is not as close up. Thanks for looking at my post and offering any suggestions. My manual does not have a diagram of how the water system should look, but to me it just doesn't look right.
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
'85-34ft Sovereign City Water Hook up E&T Stutts 1984 - 1989 Sovereign 1 10-31-2002 06:31 PM
