Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 12-28-2012, 09:17 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
Water Filtration System for Drinking Water
The previous owner may have removed the filtered water tap on our unit. I've reached the end of my rope with buying jugs of bottled water!!!
There is a hole on the counter with a cover on it that can accept a tap for filtered water. Wondering if the Culligan model is a good choice and if it will provide good tasting water and also remove the contaminants from the city water? At home, we have a reverse osmosis system but not sure I want to invest that much real estate under the sink.
Here's the one from Camping World:
Culligan RV-EZ-3 Undersink Water Filter Kit with Faucet - Culligan International RV-EZ-3 - Water Filtration - Camping World
Thank You,
Ken Tuvman
kentuvman is offline   Reply With Quote
Old 12-28-2012, 10:30 AM   #2
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
There is nothing wrong with that model, especially with replacement cartridges/filters 1/2 the cost of the Everpure which my AS has. As a fulltimer, I am seriously considering the RO option as well as some sort of RV water softening system. Cost of such systems is a consideration as well as the real estate required. Water quality is big concern of mine, but I don't have satisfying answers yet, either. Keep us posted which way you decide to go!
AIR 57698, TAC NM-9. https://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 12-28-2012, 02:13 PM   #3
flynaxos's Avatar
2008 25' Safari FB SE
Daphne , Alabama
Same thing available on Amazon for a lot less
Amazon.com: Culligan RV-EZ-3 EZ-Change RV Drinking Water Filtration System, Level 3-Advanced Filtration: Home Improvement
flynaxos is offline   Reply With Quote
Old 12-28-2012, 03:19 PM   #4
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
We use a 3M Filtrete; I got this as a replacement for the Everpure. There are cheaper units, but I like 3M products in general. This one works well, was easy to install and delivers very fresh tasting water.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 12-28-2012, 04:34 PM   #5
Ottawa , ON
Your link wouldn't work for me, Bart. Gave me their version of error 404
This one gave me the one I think you were wanting to send..?
Old 12-31-2012, 01:38 PM   #6
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
interesting thread, as full timer we are also considering a system and after a lot of research we found this one.
eSpring Technical Merits
only downsize is that is 120V but worth it! a little expensive but ebay is a good resource
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 02-11-2013, 08:34 PM   #7
Installed the Culligan unit - EZ install & water tastes a lot better than Houston tap water - no more lugging gallon jugs around!!!
Thank You,
Ken Tuvman
