I just purchased the AS.
I had filled FW tank with cleaner, emptied, filled with clear to rinse, emptied, filled with sanitizer and then was in the process of emptying again when I noticed carpet was wet.
Had my wife look under stove as I started to add water from fill door.. she yelled stop after 1/2 a second.
I looked under stove and found 1 1/2 crack in fill tube just above prior repair splice.
My three full tank fills poured water into the space under the stove the whole time.
Have all floor level tambour access doors open with the carpet lifted up and a fan stuck in trying to dry the plywood, carpet and padding
Whole tube is brittle.
I think they should have used a bigger splice insert on prior repair.
I think maybe they made it shorter and it stressed the remaining hose.
