Old 09-06-2010, 07:35 PM   #1
2007 25' Classic
Hydes
Water dripping from fresh water overflow?
I get a pretty constant drip from the fresh water overflow pipe. ( the small hole just below the fresh wayer fill hole) I thought that maybe the tank was just to full and during the heat of the day it was expanding and dripping, but I"ve drained the tank some and it still does it. I'm at a loss as to what would cause this. Any ideas?
craftsman is offline   Reply With Quote
Old 09-06-2010, 08:03 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Had the same problem and it was leaking valves in the water pump. Dealer replaced the pump under warranty although I suspect that with disassembly and cleaning it would have been fine. When the valves leak and you're connected to "city" water some makes its way past the valves to the tank eventually resulting in overflow.
Old 09-06-2010, 08:03 PM   #3
BossCamper's Avatar
1973 25' Tradewind
Chatham , Ontario
Is this tube maybe joined to the drain line with a "T" so that there is only one hole through the pan to the outside? If so, maybe your drain valve is leaking a bit, which would then drip from the same outlet as your overflow.
Just a thought. I can't see how you would be getting a drip from the overflow if the water level is below it.
Airstream Project Picture Gallery
http://lorisart.org/gallery/thumbnails.php?album=34
BossCamper is offline   Reply With Quote
Old 09-06-2010, 08:07 PM   #4
_
IF connected to shore water while this happens,
it is often back flow via the water pump.
many have had this issue...
http://www.airforums.com/forums/f443...ank-40250.html
http://www.airforums.com/forums/f443...h20-21678.html
cheers
2air'
Old 09-07-2010, 02:19 PM   #5
2007 25' Classic
Hydes
Thanks. Sounds like the water pump. Whats the "Best" replacement? Quality, reliability, and especially, quiet??
Old 09-07-2010, 02:29 PM   #6
dznf0g's Avatar
Oswego , Illinois
Just replaced my trouble prone Aquajet with the ShurFlo Extreme. It is a great pump. I did have a leak develop at the head of the pump after two weeks use. Found the 8 mounting screws just a little looser than I thought they should be. Snugged them up and all is fine for the last week under pressure. By the way, with all water faucets off, this pump WILL hold pressure in excess of a week.
Old 09-07-2010, 03:58 PM   #7
_
another vote 4 the extreme series.
after killing 3 of the oem pumps in 2 years,
the extreme is holding up much better at over 3 years of duty.
it is WAY quieter...
went with the 4.0 but if doing it again would opt for the 5.7.
the oem pump can be rebuilt for under 20$
and serve as a back up OR used as a satellite pump for filling the fresh tank OR moving waste water...
it can even be used as part of a poop grinder IF u are into maceration.
cheers
2air'
Old 09-08-2010, 06:37 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
What's this? The OEM pump can be used as a pooper pusher?
Old 09-28-2010, 09:30 AM   #9
2007 27' Classic FB
Ridgefield , Washington
Just replaced pump with the Shurflo 5.7. Will report on how it functions next week.
Woosch is offline   Reply With Quote
Old 10-09-2010, 10:25 AM   #10
2007 27' Classic FB
Used the Shurflo 5.7 for the first time last week. No problems. Wondering if it might have been overkill.
Old 10-09-2010, 10:58 AM   #11
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We just replaced our Shurflow after ten years use; great pump!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Water dripping from heat pump Loren Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-27-2015 10:02 PM
A/C Dripping Water Inside Camper Grumpycamper Furnaces, Heaters, Fireplaces & Air Conditioning 21 08-24-2010 05:13 AM
Need Help! Dripping water. Bluto Fresh Water Systems 3 06-07-2010 01:14 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
