Water Dripping from Fresh Water Inlet
I have a 2003 34' Classic S/O. My water pump ran in the middle of the night. Looked and found that there was water dripping from the City Water Inlet. I pulled the Inlet out thinking the check valve was right at the inlet. Not. It had been sitting for a while with the pump off and no water came out when I pulled the Inlet and pressure reducer off . I guess the check valve is way back inside somewhere. Anyone know how to get to the fresh water check valve on a 2003 34' Classic S/O? I'm getting ready to test my theory of what's really leaking in a minute, by turning on the pump to see what happens with the City Water Inlet uninstalled. Any help would be appreciated. Maybe I should just let it drip and turn off the pump every time I use it? Does the water pressure regulator work as a check valve? DH
