Old 05-27-2015, 09:59 AM   #1
1975 29' Ambassador
Fort Wayne , Indiana
Water drain
We have a 1977 31 foot rear bath Tradewind Land Yacht
Can anyone tell me PLEASE where the drain valve is for the fresh water that you fill from outside.
We are aware of the pull values in the back for the gray water etc.
But can't locate one to empty fresh water out of tank that was not used
ANY help is appreciated! !
tweetie1966 is offline   Reply With Quote
Old 05-27-2015, 10:44 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
My 77 Safari has 2 ways to drain the fresh water tank.
Inside the cabinet under the bathroom sink are valves that drain outside underneath the rear of the trailer, they are part of the freshwater system so the pump runs until the tank is empty.
The other method is to crawl under the trailer and remove the access panel in the tank cover, there's a valve inside that will let the tank drain by gravity.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 05-27-2015, 10:48 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Maybe things changed between '73 and '77, but on my '73 the only way to get water out of the fresh water tank is via the pump. There were several drains in the water lines designed to help you get the water out of the lines for the winter, but no "low point" drain in the tank itself that would allow you to just open up a tap and let the tank drain by gravity.
good luck!
Old 05-27-2015, 11:47 AM   #4
1975 29' Ambassador
Thanks Belegwdhel. That is what I am finding out. Airstream just called me and said there were several years where there was no under belly drain tube. He believes my unit is one.
There is no turn handle under the sink either.
So looks like we have to run the water pump with Fawcett open to completely drain.
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
