Old 12-01-2015, 05:55 PM   #1
Water collecting cistern
I have a remote campsite where I have electricity, but no water source.It is on a mountain where drilling a well is not feasible. I am building a RV port to park my Airstream, and would like to channel gutters to drain rainwater into a cistern. We will still need to carry drinking water, but could have our other water needs met by the stored water. Has anyone had experience with such a system?
jmichaelr is offline   Reply With Quote
Old 12-01-2015, 06:45 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We used to collect rain water for our cottage on the lake. It was good for washing and bathing (if you could keep the mosquitos from laying eggs and breeding in it).
Old 12-01-2015, 06:54 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
You can collect rain water in 55-gallon food-grade plastic barrels or 275-gallon totes. For the purposes you need it for, I would paint the surface of the container a dark color to keep algae from growing. Both types of containers can be mosquito-proof if there are no holes left open to the air.
Do a search on the web for tips on how to make a rain barrel. A small amount of bleach can be added to sanitize the water.
The best RAIN BARREL for less than $15, and where to find a barrel
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-01-2015, 07:03 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Runoff from gutters is considered raw surface water, and will require water testing and treatment to use for sanitary purposes— including bathing and dishwashing. Your state department of public health should have all of the necessary information for setting up a cistern system, and you will need to comply with their requirements if you want to be legal.
If a water source is problematical, waste water disposal is likely to also be a problem, and this is also a matter for your state department of public health.
If you're not concerned about legality and choose not to contact the department of public health, then a combination of sand bed filter, granular activated carbon filter, and chlorinator— possibly supplemented by a UV light filter since you have a source of electricity, inserted in between the carbon filter and chlorinator— should ensure that water coming out of the cistern is safe for use. But since I haven't tested the water to determine which contaminants are present in your water, that's a conservative suggestion and not any kind of definitive design decision.
Edit— the chlorinator is a treatment for drinking water, NOT a pool chlorinator. They're different in that a drinking water chlorinator limits the chlorine content to less than 4 parts per million, the safe level determined by the EPA for chlorine in drinking water. Even though you don't intend to drink the cistern water, the same level of treatment applies for all sanitary purposes.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-01-2015, 08:19 PM   #5
Mosquitoes do not lay eggs in clean fresh water, only in stagnant water. And water will not stagnate unless it has some kind of organic material in it. Which means that if mosquitoes are attracted to the water then it's not safe to use.
WBCCI #1105
TAC LA-4
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Rear Bump Tray Collecting Water KJRitchie 2006 - 2010 Classic (all lengths) 9 07-27-2014 03:45 PM
AC collecting water cutterbug Furnaces, Heaters, Fireplaces & Air Conditioning 32 08-22-2010 12:27 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Collecting Emoticons AirstreamGypsy Off Topic Forum 11 08-08-2006 06:57 PM
