Old 01-13-2005, 01:35 PM   #1
Ga Pockets's Avatar
valve
Any tips or pitfalls changing out a Moen mixing valve? I decided to either buy a kit or if kit is not available, the complete assembly. My problem is that I have to turn the mixing valve completely counterclock wise ( till it stops) to get a trickle (will not go out of showerhead) of hot water. the hot water pressure on the other faucets is weaker than cold pressure but is workable. I have bypassed the HWH but doesn't help. I also thought about removing the in-line prv as low pressure might be a factor. The prv is currently screwed in to city water hose bib and is an inline type similar to those sold at Walmart. I havn't looked to see if there is another one hidden away somewhere that might be the low pressure culprit.
Ga Pockets
Ga Pockets is offline   Reply With Quote
Old 01-13-2005, 02:39 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The first place to check if you have low pressure water coming out of the faucet is the screen/aerator that screws on to the very end of the faucet where the water comes out.
I assume prv is Pressure Relief Valve? If it is bad, you will know it because it will be relieving water everywhere.
A picture of your situation(s) would help immensely.
Tom
Old 01-13-2005, 05:59 PM   #3
The condition you describe is not the Moen valve, per se. Somewhere you have a blockage. As noted above, first clear out the aeator screen. Next, pull out the cartridge and remove any debris found there or in the faucet itself. If this doesn't work, start backwards from the water inlets and disassemble all connections. Small bits of rust and gravel and whatnot like to collect in connectors, particularly Tees.
Good luck,
Mark
Old 01-13-2005, 06:15 PM   #4
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
Sounds very similar to a problem we had where all hot water flow was lost in the shower. First I checked to see that water pressure was available at the shower valve inlet. After that, a call to Moen customer service (1-800-289-6636) got very clear verbal instructions on removing the cartridge and then removing the cartiridge internals and cleaning. When put back together it worked fine. One word of warning - have a spare cartridge retaining clip on hand. It is very easy to lose the installed one between the wall pieces.
pienjim is offline   Reply With Quote
Old 01-13-2005, 06:36 PM   #5
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Not difficult..
GA Pockets..
Another exchange between owners of '88's...
Advice to find out first if pressure is OK getting to faucet or is lost in faucet is solid.. Aerators on end of faucet do get really clogged with tank water and some city water stuff, or your upline filter could also be clogged..
Advantage of Moen plumbing faucets and valves is that you can find or order parts via many hardware and Home Depot/Lowes kinds of places, instead of RV stores with different markups... Do disassembly first (keep white towel on floor to catch springs and clips that will otherwise sproing into the ether...) and then take troubled looking parts to store to match...
We had separate hot and cold faucets (rather than mix valves) in bathroom and kitchen, and we swapped out for std residential sinngle lever units in bith places... Now if only I can figure out how to rebuild or stop annoying drip from shower valve...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-14-2005, 07:04 AM   #6
Ga Pockets's Avatar
Thanks all, I used to spend a lot of time on rv.net.......this forum is the best! None of the "my dog is better than your dog crap!".
Ga Pockets
Old 01-15-2005, 12:03 PM   #7
Ga Pockets's Avatar
Valve
Update, If all else fails read service manual! I took valve apart just to see if there was trash(none) however service manual gave instructions on adjusting flow for hot and cold.........just needed a5/64" allen wrench and all is good with the world.
Ga Pockets
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
