Old 04-21-2011, 06:48 PM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Unknown valves in storage locker
In my rear storage locker (accesable from outside) there are two 1/4 turn valves. They are something to do with the fresh water system because they are connected by a tee to the fresh water plumbing. Anybody have any idea what they control? They are both closed now and everything seems to work fine.
mhilley is offline   Reply With Quote
Old 04-21-2011, 07:11 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Those are probably low point drain valves for Winterizing.
Old 04-21-2011, 08:29 PM   #3
mhilley's Avatar
2000 23' Safari
You are probably correct. Probably one for cold, one for hot. After leaving the valve the piping heads down through the locker floor. Where it goes after that I could only guess. Probably right to the ground! Think I will try one and see.
Old 04-21-2011, 08:51 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Multiple valves? Are they arranged in an H pattern?
http://www.airforums.com/forums/f42/...tml#post715359
5 meter Langford Nahanni
Old 04-21-2011, 10:08 PM   #5
mhilley's Avatar
2000 23' Safari
No. My "H" valve arrangement is right next to the water heater which is amidship, road side, under the dinette seat. These are at the rear in the storage locker. We don't winterize here in Florida so I don't get to play with the "H" valves very much but I know they are there!
Basement storage compartment hinge lubrication. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 05-03-2011 05:35 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
Water by-pass valves 95cutterbus Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 08:50 AM
RV Storage for a week near Santa Cruz, CA triterra On The Road... 0 03-16-2011 02:30 AM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 05:00 PM
