Old 02-08-2015, 08:33 PM   #1
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
Two vents for grey tank?
I am in process of refurbing 1983 Excella 31' rear bath.
I demo'ed most of the bath today in advance of new pex plumbing and a new floor plan for bathroom. I noticed that there is a vent line coming off of the grey tank (just above the tee for the sink drain) that T's again to connect to the black tank vent. This "combo" vent runs around to the curbside and disappears behind the shower wall. Additionally, directly off the grey tank in a secondary location, there is another vent line that also runs behind the shower. I assume that the two vent lines join together somewhere behind the shower wall before entering the wardrobe and exiting to the roof.
Since I will be modifying the plumbing to some degree, is there a need for the two grey water vents?
Poolman is offline   Reply With Quote
Old 02-08-2015, 09:56 PM   #2
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
If anybody has some insight, here is a pic of what I have.
Old 02-08-2015, 10:36 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
The vertical pipes are vents for the sink , black tank and bath tub on our '69 Tradewind. They all connect in the corner and exit as 1 out the roof.
The horizontal pipes are the drain lines. They plus the kitchen sink lines all end at the dump valve. The kitchen sink has its own vent pipe.
Our trailer didn't have a gray tank.
The way they ran the drain and vent lines one would think they owned stock in the ABS industry
The last pic is what is looked like last month. Our new shower is going in the street side corner. It partially blocks the window.
I've run all new PEX and moved the battery and charger, added extra wiring from the new inlet. But that's another story.
I hope the pic's give you some insight on what you may have.
ID:	232023   Click image for larger version
ID:	232025   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-08-2015, 11:10 PM   #4
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
Thank you! That does help.
Looks like a bunch of redundancy in yours much like mine. Like you said, Airstream must own ABS stock
I guess it was an easy way to get the black tank vent tied in, but wonder why not just tee it in to the first grey vent instead of running two behind the shower wall? Just thinking about a more efficient, cleaner way to redo this mess.
Thanks for the pics.
Old 02-08-2015, 11:34 PM   #5
Glenritas's Avatar
1969 25' Tradewind
When I install my wet shower ,it has the black tank molded in, I will run a vent up and then across the rear of the trailer just above the PEX lines to the existing vent stack in the curb side corner.
I'll also tie into it the vent for the sink and shower vents .
The drain line will go to the forward mounted gray tank will serve the bath sink, shower, kitchen sink and washing machine.
Hmm ... sounds like I should buy some ABS stock
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 02-09-2015, 04:41 AM   #6
Central , Mississippi
The vent in the sink drain line is to allow the sink to flow without burping. When the P trap is full there is air in the drain after the trap and before the tank. Pouring watering the sink builds up pressure on the P trap until it burps and allows water to flow. Think of the vent as a drain line vent, not really a gray tank vent.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-09-2015, 09:07 AM   #7
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
Thanks HiHo. That makes more sense! It doesnt look like a replumb of the vent lines will save much space, so probably leave it as is.
Old 02-09-2015, 10:20 AM   #8
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
See post #13 on this very subject on this thread:
http://www.airforums.com/forums/f162...ml#post1578682
youngpeck is offline   Reply With Quote
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
Looking to replace black/grey tank vents polarlyse Waste Systems, Tanks & Totes 3 11-23-2014 08:48 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Sealing black and grey tank vents The Driver Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-03-2011 10:05 AM
