Old 12-06-2002, 02:07 PM   #1
Question Two PVC pipes?
There are two PVC pipes next to each other that come out the bottom of the fresh water tank on the curbside. I couldn't find anything in the manual that said what they were for, so if anyone knows, please share!
Thanks, John
John is offline   Reply With Quote
Old 12-06-2002, 02:28 PM   #2
1975 31' Sovereign
Eau Claire , Wisconsin
John, I am assuming these pipes are approximately 4 inches in diameter, are capped, and run approximately the width of the coach. I have similar pipes on my unit and stashed inside one of them is drainage hose for draining the waste tanks and the other one contains an auxiliary support strut for my awning.
Brouck
bhsl8 is offline   Reply With Quote
Old 12-06-2002, 02:43 PM   #3
They point towards the ground
These are about 1/2"OD, they point towards the ground and come out next to the fresh water tank.
Old 12-06-2002, 03:10 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
check your other thread
john
check your other thread.[URL=http://www.airforums.com/forums/showthread.php?s=&threadid=2746]
those pipes are your low point drains
john
Old 12-06-2002, 03:30 PM   #5
where the hell is it???
John,
I thought I had that thread here in general repair, but I can't find it. Please help out the mentally challenged and tell me where it is
John
Old 12-06-2002, 03:45 PM   #6
I can't see my threads?
John,
When I go into the "General Repair" forum, I don't see my posted threads. The only reason why I'm typing this now is because I'm here via the email notification that someone has replied to my thread.
I see everyone elses threads, but not mine. Any ideas? I reviewed my user cp options and everything looks good. I just can't figure out why I can't view them.
I emailed Bobby W on this, but haven't heard back as of yet.
John
Old 12-06-2002, 04:01 PM   #7
LOST , Hawaii
I moved it to the 'Plumbing, Water Heaters, Toilets, and Tanks" in the Interior Restoration Forum, just trying to keep everything organized. If you go there you will find that one and this one.
John
74Argosy24MH is offline   Reply With Quote
Old 12-06-2002, 04:35 PM   #8
In the future, could you please let us know when you move one of our threads?
John
Old 12-06-2002, 04:39 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
johnjohn
john
did you ever find my post?
john
Old 12-06-2002, 04:43 PM   #10
I'm from Mass
JohnHD,
Sure did and thanks!! I'm going to get out the manual and take a closer look.
John
Old 12-06-2002, 04:56 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chicks dig guys named john
john
fyi, there is one other drain at the rear of the trailer near the entrance of the city water hook up. this is for draining as well.
john
Old 12-06-2002, 04:59 PM   #12
1/2 in pvc pipes
hey john they are the low point drains if you turn on the valves under you bathroom sink and turn your water pump the water from your fresh water tank will drain from these pipes its very handy when you are winterising your trailer
paul k is offline   Reply With Quote
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Where do these water pipes go? letsgo Fresh Water Systems 1 12-21-2003 07:56 PM
PVC Valves davespann Mechanics Corner - Engines, Transmission & More... 1 03-02-2003 08:43 PM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
PVC waterlines? buckmaster Fresh Water Systems 2 11-09-2002 06:43 PM
