Old 04-07-2010, 05:19 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Trouble with gatorbite/PEX repair
I did not winterize correctly and split a copper pipe. The pipe had two old repairs where it was spliced with rubber hose leftover from the previous owner, so I removed both of those repairs, and that allowed me to pull out a six foot section of copper pipe which included the split section.
I bought a couple GatorBite (Lowe's version of Sharkbite connectors) and some PEX, cut it to fit, and installed it - so each GB connects PEX to the old copper system. Problem is one connection is fine, and the other one leaks on the copper side. I pulled it off and cleaned the copper pipe with sandpaper and made sure it was nice and clean and smooth, put it back together, and it is still dripping when I pressurize the system. I even tried another brand new GB connector and it also leaks.
What else can I check? Is it possible this old copper pipe is just slightly misshappen and so it won't seal? Has anyone else dealt with this?
Stephanie
Old 04-07-2010, 05:27 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We switched all of our water lines to Sharkbite fittings with 90% pex and 10% copper in the shower where it is exposed. Our copper was new though. We really didn't have any leaks once we got everything trouble-shot. My "guess" is that you have one of two problems:
1) Is it possible that that portion of copper is a distorted shape from the freeze? If so, by cutting it back further you may get to a round section that will fit properly and won't leak.
2) Are you sure it is pushed in all the way? Sometimes it's hard to tell, but with SB, there was a definite "click" when it goes in all the way. Also, the cut edge has to be pretty even and flat for it to fit properly.
One other thought, would be to try a Shark Bite and see if it works any better - I know it's a bit more expensive, but if it's only one fitting...you never know, it might make a difference.
I HATE plumbing issues - they are the evil undoing of many an Airstream!
Shari
Old 04-07-2010, 05:37 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I can only think of a couple of issues:
Misshapen copper, un-square cut or a burr on the copper. And possibly a bad fitting, try turning the fitting around and see if it still leaks on the copper side. If so it is the pipe.
Aaron
WBCCI #XXXX AIR #2495
Old 04-07-2010, 05:38 PM   #4
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Do not know for sure but you will probably need a fitting that goes from copper to pex. Dave can help you, he probably will see this and post.
Good luck,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 04-07-2010, 05:39 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the pipe was the right length and you inserted it all the way,insert a section of pipe into a fitting an mark the pipe at the edge of the connection, the only other problem would be an out of round pipe.
Before you install the next section of plastic mark the pipe to the same distance on the test piece you did as a test. This will give you a good indication the fitting is completely on. Sometimes working in tight places it is hard to know you have bottomed out in the fitting.
2004 Excursion 4x4
Old 04-07-2010, 05:55 PM   #6
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Appears everyone has covered all of the bases.Dave
easyride is offline   Reply With Quote
Old 04-07-2010, 05:57 PM   #7
byamcaravanner's Avatar
1967 28' Ambassador
1970 29' Ambassador
Waukesha , Wisconsin
Stephanie,
Shari hit the nail on the head. Freezing water in copper pipe will cause it to expand. The Sharkbite fitting will not "bite" correctly.
I recall a thread long ago in which the poster could not find copper sweat fittings that fit his existing pipe. He brought a sample to a pro plumbing supply store to find out what size copper he had... the answer he got was "you have no size"
If you can, try to install a longer PEX segment... you may get to a point where the copper did not freeze.
Good Luck!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 04-07-2010, 06:19 PM   #8
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
It felt like it clicked into place, but it's still dripping, so I guess maybe the pipe is out of round. I can cut off a bit more. I'll have to move to the other side of the wall into the bathroom closet, and cut it off there. This is such a pain to fight with! These pipes are in such tight spots and so tight to the floor it's hard to get two hands on it at once!
Stephanie
Old 04-07-2010, 06:25 PM   #9
HowieE's Avatar
Images: 12
You have plenty of room there. Go to the Big Box Store and get a close quarters cutting tool. The tool will also tell you if the pipe is round. Lightly tighten the tool on the pipe and rotate it once around the pipe. If the pipe is round the feel to turn the tool will be equal all the way around.
2004 Excursion 4x4
Old 04-14-2010, 04:25 PM   #10
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
The copper pipe was a little out of round. I couldn't get the gatorbite fitting to seal, even after I cut it back as far as I could to what looked like good pipe, it still wasn't sealing. I went back to Lowes and got an Apollo compression fitting. It looks like it has an extra O-ring inside, so I hoped it would seal better. It seems to have done the trick, no leaks for the moment.
Stephanie
pex, plumbing, leaks
PEX in the Sovereign Zeppelinium Fresh Water Systems 29 11-09-2008 02:29 PM
PEX Conversion Sundance Fresh Water Systems 18 07-12-2007 04:12 PM
pex crimping rama777 Fresh Water Systems 5 10-28-2006 04:44 PM
Pex Flair-It azflycaster Fresh Water Systems 3 01-23-2006 08:31 AM
CPVC vs. PEX? 3Ms75Argosy Fresh Water Systems 6 02-10-2005 07:37 PM
