Old 04-26-2015, 12:00 PM   #1
2009 25' FB Flying Cloud
Marysville , Washington
Traveling with a full tank of fresh water?
We have a (new to us) 2009 Flying Cloud. Is it OK to travel with a full water tank?
We previously had another brand of trailer (toy hauler) and when we traveled with a full tank it actually bent the bracing under the trailer. Granted the tank on the toy hauler was enormous, but we need to be sure on the Airstream.
I searched for this question in other Forum posts and could not find the answer. Everyone has such great information to share. Thank you so much for your helpful input.
J&J AIR is offline   Reply With Quote
Old 04-26-2015, 12:23 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Yes.
Welcome to the forum!!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-26-2015, 12:32 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Yes, a good idea. It helps lower the center of gravity too
Hiho Silver is offline   Reply With Quote
Old 04-26-2015, 12:41 PM   #4
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
All those that boondock do!
Silver Hawk is offline   Reply With Quote
Old 04-26-2015, 12:41 PM   #5
2012 30' Classic
Homosassa , Florida
We always travel with a full tank. Congratulations on your "new" trailer.
Tater is offline   Reply With Quote
Old 04-26-2015, 01:59 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If we are going to boondock, we fill up but if we are just going from full service to full service campgrounds, we will keep between 25% and 50% for "casual" use on the road and in case of an emergency.
Bob Martel
WBCCI# 5766
Old 04-26-2015, 02:08 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I always do. Have not bent or broke anything because of it.
MICHAEL
Old 04-26-2015, 02:11 PM   #8
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
fill 'er up
I had a dealer once tell me that I should drain it for "fuel economy" (or leave the dog behind ?)
about 8lbs per gallon, if your set up is that close then water isn't the problem
timhortons is offline   Reply With Quote
Old 04-26-2015, 02:36 PM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The Airstream was designed to carry a full tank of water.
Old 04-26-2015, 02:44 PM   #10
Thank you all for your response! We feel confident that we can travel with a full water tank and not have any problems. Everyone has so much Airstream knowledge that they are willing to share. It is so much appreciated.
Old 04-27-2015, 11:56 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The trailer rides much smoother with a full water tank. I need to fill my water tank now. I drained it for the winter and have not refilled it.
It is good to have on board water so you can flush the toilet anytime while traveling and not hooked up to city water. It is also good to have water on board in case you are leaving camp before daylight and want to be road ready before dark the day before. You can be totally ready to roll, not hooked to city water, and still take a bath and use the bathroom.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-27-2015, 07:59 PM   #12
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
We always travel with a full tank, 10s of thousands
Of miles and no problem
dannydimitt is offline   Reply With Quote
Old 04-27-2015, 10:12 PM   #13
Wolf Alaska's Avatar
Madison , Alabama
Another good reason to have water on board
Recently in a Navy (govt owned) CG, we were greeted on Friday morning with flyers all over the CG saying the CG water is unsafe. NOT use it w/o. boiling it. CG & public works didn"t say water was OK until Monday PM.
We used our on board water which was good water. Almost everyone else in CG had enough onboard water & did the same.
The people who work @ this Navy. CG know nothing about RVs or RVers.
Let's Roll !
Wolf
Wolf Alaska is offline   Reply With Quote
Old 04-27-2015, 10:16 PM   #14
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Where is the fresh water tank located? I know from the parts diagram that the black water and grey water tanks are nearly above the drains. Is the fresh water tank on the road side of the trailer where it helps to offset the weight of the kitchen and contents of kitchen cabinets?
I have been told that due the way roads are crowned, it is important to load cargo trailers (in general) with more weight on the road side, or at least to avoid overloading the edge of road side. Thoughts?
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Full timer looking for fresh tank repairs in DC area almcate Fresh Water Systems 3 04-26-2015 04:12 PM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
Driving with fresh water tank full - is it OK? bovk Fresh Water Systems 72 10-07-2013 02:56 PM
Traveling Full-Time as a Freelancer SrslyAwesome Full-Timing 11 08-02-2012 04:39 PM
Working and traveling full time scorpiontimo Working on the Road 6 01-29-2011 04:47 AM
