Old 04-03-2014, 04:36 PM   #1
2011 23' FB International
Centennial , Colorado
third white water valve?
Underneath our 2011 International 23FB there are three valves together. Two are brass, the fresh water drains. One is white plastic. Can someone remind me what it is? I also don't know which position is open. Thanks!
davidmenges is offline   Reply With Quote
Old 04-03-2014, 04:46 PM   #2
2013 25' FB International
Flagstaff , AZ
Brass is low point line drain. PVC (plastic) is tank drain. Push back to close, toward you is open.
RT66 is offline   Reply With Quote
third drain valve under galley where??? larry b Fresh Water Systems 7 04-29-2010 06:21 AM
Third Generation C/K Suburbans Sugarfoot Tow Vehicles 2 04-29-2007 09:36 PM
Contemplating a third coach... till 1967 Overlander 4 06-01-2006 09:50 PM
Cooked THIRD 700R-4 GM Suburban Transmission. Andrew M. Franklin Tow Vehicles 38 12-21-2005 10:19 AM
third axle bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 05:32 AM
