Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 08-27-2009, 03:20 PM   #1
Profile:  1958 22' Flying Cloud
Pueblo West , Colorado
Tank pressure from grover air pump
I have a 58 flying cloud and I just got my pump working and was wondering what pressure it should keep my tank? I was working on it and put a gage on the stem outside and it showed 40 lbs. What pressure should it be before it quits pumping?
Ron
Ron Banks is offline   Reply With Quote
Old 08-27-2009, 03:47 PM   #2
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
The documents that came with my 1960 says the pressure switch was originally set for max 60 psi. On at 40 and off at 60. That being said, I set mine for approximately 25/45. Until I replumb the entire thing, I'm taking the low road.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 08-27-2009, 05:26 PM   #3
Profile:  1963 24' Tradewind
San Diego , California
60/40 is also what i heard. on my inlet area there is a spot where is says max. air 65lbs, i keep mine at 45/35 or less.
Sixty3TW4US is offline   Reply With Quote
Old 08-27-2009, 05:36 PM   #4
samb's Avatar
Profile:  1961 22' Safari
Union , Oregon
Images: 11
After I was sure that the pressure switch was operating, I checked the pressure and found the pump to come on at 24 psi and off at 45 psi. Even though I had pressure checked my new water system to 70 psi I find the the 24/45 split to be quite adequate for my needs and didn't feel any necessity to adjust the switch. There is also no benefit from pushing the system to its limits.
Sam
samb is offline   Reply With Quote
Old 08-27-2009, 05:49 PM   #5
bevman's Avatar
Napa , California
60/40 is what my research has told me, but no need to run it that high. I do, and haven't split anything, yet. I replaced the pressure controller after rebuilding the pump because you can't just replace the diaphragm. (Everything worked until I tried to use it the first time). Make certain that the pump has oil in its crankcase (mine was dry and seized up).
bevman is offline   Reply With Quote
Old 08-28-2009, 07:17 AM   #6
This is probably a dumb question but how do you set your pump for the desired pressures? When I fixed the pump I noticed that the pump had a air port on top of the housing and when I turned the pump on it spit some oil out, is this normal? The port is circular and has holes drilled into it. Is there anything like a filter that goes into that little hole?
Thanks guys
Ron
Old 08-28-2009, 10:04 AM   #7
samb's Avatar
Union , Oregon
Images: 11
Grover air pump
Here's a photo of my spare Grover. The pencil is pointing to the air filter. If this looks like yours give me a PM. I could send you some more photos and might be able to answer your questions.
Old 08-28-2009, 11:44 AM   #8
bevman's Avatar
Napa , California
In samb's photo the pressure controller is like mine (the one that I replaced with new). Inside that gray box are two threaded rods with springs and a nut on the top of the spring. One is "cut out" (high pressure) and the other "turn on" (low pressure). Turning the nut in/out adjusts. You'll need to figure out which is which, and fiddle around with them.
As to the spitting of oil, this is really a small, unsophisticated piston engine. It doesn't have piston rings, so a little oil, passing from the crankcase up to the top of the piston does happen, particularly if you overfill the crankcase. My guess is, that this oil issue will stop, but not certain. There is small slot on the side of the piston where air is sucked in. Mine had a tiny felt pad (air filter) that was all gummed up after 50 years. I cleaned it with solvent and put it back.
Old 08-29-2009, 07:20 AM   #9
That is the same pump I have! The port I am talking about is on the other side from where he has the pincel pointing. It is not on the cylinder, it is on the case. I am sure it is a pressure release or overfill release of the oil. I filled the oil tank up and it spit some out that little port. Thanks for all you help guys!
Ron
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
Air pressure in front air bags on LY Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 10:50 PM
Grover air compressor oil? samb Plumbing - Systems & Fixtures 10 01-19-2007 11:07 PM
Water Pump Pressure PhilMateo Water Heaters, Filters & Pumps 2 12-20-2005 08:16 AM
Air pressure for rear air bags Jon Smith Towing, Tow Vehicles & Hitches 2 08-12-2003 10:08 PM
