Old 11-10-2010, 09:12 AM   #1
Rivet Dude
1972 21' Globetrotter
1987 34' Excella
yep, still on the road , On The Road
tank out, best way to clean
greetings:
during frame repair/paint, removed the H2O tank from my 72 globetrotter. appears to be in great shape, no leaks. while it resides safely in my garage during futher work, what would be the best way to clean this baby out? no debris inside, but through the 1.5 inch opening, I can see various "scums". I was thinking of filling with ice, rock salt, and some cold water, give a good shake to "scrub" it. then a good flush. any body have other suggestions would be appreciated.
thanks
airjeff
airjeff is offline   Reply With Quote
Old 11-10-2010, 09:37 AM   #2
Lothlorian's Avatar
Loganville , Georgia
10% pool chlorine and water. It will eat the scum. It may smell like chlorine after you rinse it, but that will go away.
I have worked with chlorine and I think it works great. If you want to eat the scum immediately you can use muratic acid. Where protective clothing , rubber gloves, maske and goggles. I would do a 10% solution of muratic acid also.
Always wear protection.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 11-10-2010, 11:46 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
How do you empty the water from the fresh water tank? This might seem like a simple question but I have never owned a TT of this magatude. Only a pop-up and it did not have anything. Tent on wheels with a built-in stove coleman stove and 12v lights. Thanks for the info on the pool chlorine mix.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-11-2010, 04:47 AM   #4
Lothlorian's Avatar
You should have a pump. Just get a siphon and use it, or rent a pump.
Brian
Brian & Adrienne
Old 11-11-2010, 08:27 AM   #5
Rivet Dude
1987 34' Excella
great idea. will use this technique over the weekend. as far as draining, in the trailer it has a very slow drain valve. easier to pump the water out.
Old 11-11-2010, 09:09 AM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks - was wondering - my pump is dead and was wondering if there was another way. thanks again.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Need to clean fresh water tank? tcrum Fresh Water Systems 4 04-07-2010 09:25 AM
How to clean the tank azfiredog300 Fresh Water Systems 4 03-29-2008 11:05 PM
How can you tell if your freshwater tank is truly clean? JimGolden Fresh Water Systems 24 10-30-2007 08:44 AM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
