Old 06-15-2010, 07:58 PM   #43
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
A pic of Roger holding his new monitor panel (this was just taken at the Restoration Rally in Albuquerque).
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 10-29-2010, 07:49 AM   #44
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
If anyone wants the panel design in Corel, CAD (DXF), CAD (DWG), or Autosketch (SKF), drop me a line using regular email and I'll send them to you. You can use these files as a basis for your own design, or leave the layout the same and just change the text labels.
Zep
Old 10-20-2012, 04:58 PM   #45
1993 25' Excella
Sacramento , California
I have a 1993 Excella and the tank monitor says the tanks are part way full when they are empty. The manual says I have a bad panel. Is that the problem and if so where can I get a replacement?
Scott CoBen is offline   Reply With Quote
Old 10-20-2012, 07:34 PM   #46
1975 31' Sovereign
1977 23' Safari
Scott, the monitors changed over the years. I don't know how yours worked. The early 70s used four wires (or so, depending on the tank) to light the light bulbs. In the mid 70s that changed to two wires and some resistors, but it was still a pretty simple conductive measurement device. Later, the system measured pressure.
You can buy a new pressure measuring system and install it, since the voltage sent by the transducer can use the same wires that either system (pressure or conductance) used. I don't think the older systems are supported by Airstream any longer.
I don't supply units, just the poop for you to make it yourself.
Zep
Old 10-11-2013, 09:55 PM   #47
1975 31' Sovereign
1977 23' Safari
New news!
I have "discovered" a very easy to program microprocessor product from Arduino that can provide a complete monitor system in one small $12 PCB and a small additional PCB to hold the LED level indicators.
This Arduino device has 8 analog inputs, so it can do a lot more than just the tank levels. More to come.
I enjoyed tinkering with the dedicated logic of the monitor described in this thread, but adjusting the resistors to match the input voltages was a true pain and took a lot more time that just changing the voltage levels in software in the Arduino.
If you're interested in replacing your tank monitor, look for a future post titled "Arduino Tank Monitor". This one will be a piece of cake, believe me, compared to using dedicated 7400 logic chips. Not to mention easier to build and cheaper.
Zep
PS--the Arduino can monitor the fresh tank for freezing, watch the battery voltage and current, and record indoor and outdoor temperatures. More on that later, too.
Old 10-12-2013, 04:31 AM   #48
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Subscribed!!!!
Our AS monitors haven't krapped yet...but I have some boat applications in mind.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-23-2013, 01:56 PM   #49
1975 31' Sovereign
1977 23' Safari
This is the prototype of the digital tank monitor. Note that it has battery volts and amps at the top and tank temperatures for each tank. The full thread on this little beauty might be ready by the New Year--watch for it.
Total cost: cpu card $10, display $20, temperature sensors $6, current sensor $4--$38.
Z
Name:	DSCN1828 proto monitor.jpg
Old 11-23-2013, 05:26 PM   #50
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Awesome!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-23-2013, 06:37 PM   #51
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Would be cool to have info sync to my iPhone in real time via Bluetooth or wifi
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 11-23-2013, 07:16 PM   #52
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Z
I would buy one!!
Silverflames is offline   Reply With Quote
Old 11-23-2013, 09:55 PM   #53
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Does this mean u use the existing tank probes?
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-23-2013, 09:58 PM   #54
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Cool idea
Channing
WBCCI# 30676
Old 11-24-2013, 03:42 AM   #55
1975 31' Sovereign
1977 23' Safari
It could be done, but since I only have a [stupid] flip phone I could never test the app. The Arduino microprocessor family has Bluetooth interface cards.
Z
Old 11-24-2013, 05:49 AM   #56
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
That would be cool feature.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 01:09 PM
Micro-Pulse tank monitor blues dlb435 Waste Systems, Tanks & Totes 11 07-14-2009 01:53 PM
looking for tank monitor replacement parts rec Plumbing - Systems & Fixtures 3 08-04-2008 08:18 AM
Digital TV jcanavera Audio, Video & TV 3 02-02-2007 10:51 AM
Tank Monitor Help pmclemore Electrical - Systems, Generators, Batteries & Solar 4 01-31-2006 12:41 PM
