Old 03-21-2012, 12:44 PM   #15
tpi
Trabuco Canyon , California
I thought of something that would be useful to me.
How about a meter, similar to a home water meter, on the output of the water pump? It could have remote readout, with a zeroing function.
Simply monitoring fresh water use would be handy. I have a pretty good idea most of it ends up in the gray tank. For me this info is much more useful dry camping. On hookups I can go pull the handles anytime.
tpi is offline   Reply With Quote
Old 03-22-2012, 06:11 AM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
RE: Gauges that work and gauges that don't…
Apples and oranges. Speaking as a mechanical engineer, any mechanical gauge (like your automobile's fuel gauge) relies upon measuring a fluid with a consistent specific gravity, like clean water or gasoline, with no debris in the tank. If you measure a fluid with suspended solids (like effluent in a blackwater tank), or a varying specific gravity (like soapy water in a graywater tank) then a mechanical gauge is just as likely to give a false reading or quit working altogether.
Electronic gauges are still evolving. Inside-the-tank gauges like your Catcon Micropulse are still subject to problems caused by the tank's contents, but lacking any moving parts, they are less vulnerable to damage and wear-&-tear than a mechanical gauge.
There's a good reason why the boating and RV industries are moving to outside-the-tank sensors like the ones on my Interstate's tanks. Whether they're the best in the long term remains to be seen, but at least the industry perception is that right now, they're more reliable and easier to work on when something does go wrong than either mechanical or inside-the-tank electronic gauges. Safer, too. Because you don't have to drill holes in the tank to mount them, you aren't exposed to the tank's contents and you don't create potential leaks; that's one reason why the same sensors can be used on my Interstate to monitor propane tank levels along with the fresh- gray- and black-water tank levels.
If it was up to me, I'd replace the existing Catcon Micropulse sensors in your trailer with drain plugs screwed into the same holes, and install an all-new external sensor system. But it's not up to me, and my advice is like any advice; use, ignore, or mock as you see fit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-22-2012, 07:09 AM   #17
1965 22' Safari
Send a message via Skype™ to chromis
Anyone had experience with SeeLevel style capacitive sensors ? or rolled their own using a chip like MPR121 Capacitive Touch Sensor Breakout Board - SparkFun Electronics ?
chromis is offline   Reply With Quote
Old 03-22-2012, 08:24 AM   #18
fmrcaptevil's Avatar
Weldon Spring , Missouri
Would an external sensor system be practical for use with these very shallow tanks?
fmrcaptevil is offline   Reply With Quote
Old 03-22-2012, 08:41 AM   #19
1974 Argosy 20
Kooskia , Idaho
Trade it for an old Argosy TT. We don't need no stinking gages. Mine on the Argosy which don't exist, work as well as any on my Airstreams, over the years. They got it right.
Old 03-22-2012, 10:17 AM   #20
The tanks on my Interstate are less than a foot tall, top to bottom, and external sensors work on them.
WBCCI #1105
TAC LA-4
Old 10-20-2012, 05:14 PM   #21
1993 25' Excella
Sacramento , California
I have a 1993 Excella 25' and the gauges aren't working. How can I tell if the black and grey water tanks are full without the gauges?
Scott CoBen is offline   Reply With Quote
Old 10-20-2012, 05:20 PM   #22
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you should be able to check you black tank by looking into the toilet. And the grey tank will start to fill the shower.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Can't get water to pump from fresh water tank xbr443 Fresh Water Systems 6 01-20-2015 06:34 PM
Black tank gate valve doesn't close all the way motozen Waste Systems, Tanks & Totes 14 09-08-2014 01:38 AM
I think the tornado got my tank shroud perryg114 LP Gas, Piping, Tanks & Regulators 8 04-29-2012 12:50 PM
Lost Screen on hot water tank? stowaways On The Road... 1 03-18-2012 08:01 PM
xantrex linklite vs trimetric 2025A battery monitor demondeacon3 Batteries, Univolts, Converters & Inverters 8 03-17-2012 06:55 AM
