Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 06-16-2012, 04:39 PM   #1
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Tank gunk -- help
Anyone know what this black stuff is and how to get rid of it? It's only on the top and sides (inside the tank).
Name:	DSCN0042 tank gunk-s.jpg
I'm going to modify the tank with two 3/4" drains in the bottom. I can get the Metal Company in Denver to spin in the flush fittings.
BTW, when I was checking the tank for leaks I noticed that the vents are about 1" down from the top in the 5" tank. That means that if you fill the tank with the trailer level, you only get about 80% capacity. Depending on which side your kitchen is on (generally the tank fittings are on that side), you need to have that side of the trailer high, maybe 5 degrees, in order to fill the fresh tank to something like 95% capacity.
Zep
Zep@Charmedquark.net
Old 06-16-2012, 05:06 PM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
In an old geology class, we were taught to do a couple of tests after the initial visual: Sniff and taste. (Naturally, the teacher then explained that what we'd all sniffed and tasted was petrified dinosaur poo. I'm assuming that what you've got is something different.)
Lynn
ACI Big Red Number 21043
Old 06-16-2012, 05:10 PM   #3
SteveH's Avatar
Common Sense , Texas
If I had to guess, I'd guess mold, and I know that's not what you wanted to hear. Clorox should kill it.
Old 06-16-2012, 05:42 PM   #4
1973 23' Safari
1977 23' Safari
I'm only concerned about making the tank plastic brittle, I want to be careful about strong agents in the tank. If the Clorox is safe in this regard, I'm sure willing to use it--the smell will be gone pretty quick.
I'm willing to bet that most people have this stuff in their tank, but since they never look, they don't know it and it doesn't hurt them.
Zep
Old 06-16-2012, 06:00 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I don't think you'll harm the tank if you don't leave it in full strength for too long. I'd position the tank so that the bleach hits the stuff directly and let it stand for a while, then fiinish filling the tank with fresh water so that the bleach gets diluted...and let that sit for a day at least. You'll need to rinse it several times to get rid of the bleach and taste, but that should kill whatever it is, and hopefully clean it...
For what it's worth ... I can see the top & sides of our fresh water tank (it's under the dinette), and it looks clean. We never drain it completely. Granted, ours is a relatively new AS, and we're the only ones who have used it ... but to help avoid this type of problem, whenever I fill our fresh water tank from an unfamiliar water source (in campgrounds, etc) I add a bit of a weak bleach solution...not enough to taste, but enough to help purify the water. We use our fresh water for cooking and drinking. So far so good ... and no bad taste.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-16-2012, 06:06 PM   #6
Ottawa , ON
Zep,
If bleach worries you, how about putting the tank back in your TT and taking a long drive down a bumpy road with a ton of crushed ice in the tank?
I'm with Steve, BTW. What could it be besides mould, or just plain dried poo?
Old 06-16-2012, 08:21 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Zep....last year, maybe two, someone mentioned the use of a powdered type chemical used in swimming pool cleaning and sterilization.....look for it and I will search around too.
Old 06-16-2012, 09:06 PM   #8
Ottawa , ON
Of course, there's always the GEO Method.
He is convinced that bleach doesn't hurt the tank, but the main things he leans on are a soap product and water softener. It makes a lot of sense, and members who have tried it in this thread seem very pleased with the results...
Old 06-16-2012, 09:19 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
Above-floor Argosy tanks receive plenty of light and can get that glorious aquarium green. I'd tend to do the following only with tanks removed (as yours are and my Argo tank was way back then). It took me a couple gallons of full strength bleach to finally get it cleaned out.
Bleach is a really strong scavenger of organic material (mold, algae, etc). 5.25% sodium hypochlorite as you buy it is stabilized. Add any amount of water and you have to use it within hours. Yes, the smell will be gone pretty quick. Not immediately -- but dilution + days + venting should take care of it.
5 meter Langford Nahanni
Old 06-16-2012, 10:07 PM   #10
Wabbiteer's Avatar
Jupiter , Florida
Having uncovered a large wet bath-towel weight & size mat of algae in the Overlanders FW tank you have my condolences.
Even after letting the drain stay open for over a month that waiting surprise when I scooted back the tank locker floor AND 2/3rds of a tank of water that slammed half the tank down to the ground folding the plastic neatly at the molded partition scared me. The mat was evolving into consciousness and attempting to control its environment by plugging the drain line. Seeing the blob doubly decided that tank was history, and it fought back by promptly plugging the holes I drilled in the tank to drain it. The relief I felt tucking the tank into the "jaws of doom compactor" and being allowed to crush it by the trash truck hauler was worth whatever hassle waits in the future with FW tanks.
If'n I were you I would not hesitate to skip the sanitizers and move straight to muriatic acid (swimming pool acid) solution of hydrochloric acid. The plastics are immune but the sensor pickups might flinch at it so remove them if possible.
A very good sanitizer class is Bromines - hot tub sanitizers. This change from Chlorine based chemicals helps keep resistant organisms from blooming into city block sized mats scrunched into the plastic tank.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-16-2012, 10:16 PM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Canoestream got it.....Sodium hypochlorite - Wikipedia, the free encyclopedia
Thats what I was thinking of. Available inexpensively at pool supply houses.
Old 06-16-2012, 10:28 PM   #12
5.25% Sodium Hypochlorite in aqueous solution is commonly called bleach, Clorox, etc. Melody Ranch, is the pool stuff liquid?
Aha! From Wikipedia on the 'stabilized' point: "Household bleach and pool chlorinator solutions are typically stabilized by a significant concentration of lye (caustic soda, NaOH) as part of the manufacturing reaction. Skin contact will produce caustic irritation or burns due to defatting and saponification of skin oils and destruction of tissue. The slippery feel of bleach on skin is due to this process."
I do know that you can't dilute bleach and then store it. That defeats the stabilization. A bit off topic...
Old 06-16-2012, 11:47 PM   #13
webspinner's Avatar
Menlo Park , California
Hopefully it isn't poo since this is a fresh water tank.
Barbie
Our travel and renovation blog: https://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 06-17-2012, 05:11 AM   #14
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
I would use bleach to clean the tank. One trick to get rid of the bleach taste is to fill the tank with a vinegar water solution afterwords. Let it sit for a day and all bleach taste is gone. The plastic tanks on our boat look like yours every spring! First bleach and then the vinegar and everything looks and tastes new again. By the way, have you wondered what the inside of all the fresh water lines look like? I'd treat everything...
Bruce
Bruce B is offline   Reply With Quote
Old 06-17-2012, 08:39 AM   #15
Ottawa , ON
Oh! Well, all bets are off.
Zep put the word "fresh" only down at the end of the post; my Sov is about the same age as his, and the black tank looks a lot like his fresh tank, however the ridge down the middle should have twigged me to the fact that it's the fresh tank.
No Geo plan for the fresh tank, IIRC. Even ice would be awkward to get in there.
Old 06-17-2012, 10:19 AM   #16
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
They do make a cleaning kit for fresh tanks you can pick up at an rv deal. They work pretty well. I used one on my old tank when we first got the AS.( lets just say it had growth, worst than yours) I ended up replacing the tank a few years later though.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-17-2012, 12:04 PM   #17
1981 31' Excella II
New Market , Alabama
Bleach won't hurt the tank for short term exposure. It is probably HDPE. The suggestion of using warm water and vinegar is a good one after the bleach and is what I use to remove rubber taste from my Camel Bak water bladder. Using a milder solution of bleach say 10 ppm would be great for a yearly sterilize. You should be able to find out the ratio to produce 10ppm from household bleach somewhere online. I would use a couple gallons of bleach for your tank minimum. Pool shock is another alternative.
If you can get some strong hydrogen peroxide that will work great and won't leave a taste. Some folks on here use a peroxide mixture to clean their shower stalls.
Perry
Old 06-17-2012, 12:48 PM   #18
Baltimore , Maryland
Zep, I would not recommend pool products. Pool products are meant to not degrade quickly. I think if used, you will end up smelling chlorine for a long time. Regular house hold bleach will do just fine for you. Throw in some ice and you should be able to use it to scour the film off. You could always buy a new tank and not worry about any of it. That is the route I have taken twice now in your very situation...
