Old 07-17-2014, 06:31 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by dznf0g View Post
When you press the button, the led beside the tank name will flash, then show the series of leds to indicate the level by color and number of leds lit.
Rich, thank you
MICHAEL
Old 07-17-2014, 06:36 AM   #16
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Ag&Au View Post
I have an effective alarm system for the fresh water.
When the water stops coming out the tap, I get alarmed.
I always top up the fresh water before leaving home or any any camp site with water, unless I am going to be home that day. If I arrive home with water in the tank, I regard it as free irrigation for the hedge and flowers next to the driveway.
I guess the reason, the factory systems works well in my trailer is because I don't care about it.
Ken
See now, I can't live with that one. My wife has a tendency to get up on departure morning and change her mind about not showering until we arrive at our next destination. My greatest fear is her running out of fresh water with shampoo in her hair or the shower puddling up around her feet, because I didn't use the blue boy or haul some water last night.
Those two monitor readings must be known quantities for me!
-Rich-
Old 07-17-2014, 09:52 AM   #17
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
That's never a problem for us, because we always make a leisurely departure when traveling. Wife and I both shower if applicable, then I do the tanks. For me, making a early departure ruins my attitude for the whole day. Anything that spoils that plan is viewed by me as trying to go too far in one day. It would not be a vacation.
Ken
Old 04-30-2015, 07:14 PM   #18
2007 31' Classic
Kingston , ON
Rportillo - when you calibrate your fresh water tank, make sure you are not calibrating "full" to the level of the intake. That is, the position of the fill-tube on the curb-side of your trailer is probably about 2ft. above the tank. If you fill right to the top of that tube, then the sensors will read at least twice the pressure. Then once the litre of water in the fill-tube is evacuated, the tank will read half-full (even tho it is completely full). That is the real downside to this sensor. You have to guess when the water is down to the level of the tank itself.
That being said, I have had little luck with this sensor and have basically abandoned it. My bigger problem is that my fresh water tank (54 gal) is bigger than my gray water tank (39 gal). And I never use very much water in my black water tank. I wish Airstream would get over the delusion that grey water should never mix with black water and design a 65 gal freshwater/ 65 gal waste water system. It would simplify things, and be less expensive to build.
trvler is offline   Reply With Quote
Old 04-30-2015, 07:40 PM   #19
aftermath's Avatar
Spokane , Washington
I would strenuously disagree with this. If you ever boondock it is very nice to have grey water and black water in separate tanks. Years ago Airstream did mix the grey with the black and learned from this engineering mistake. If all you do is camp with full hookups then either way makes sense.
My black tank sensor has never worked. It always reads empty but that is not an issue with me. I can look down the shute and decide for myself. I don't trust the battery level reading and have purchased a rather inexpensive little doo dad that plugs into the 12 V receptacle and gives an accurate reading. I have recalibrated a few times and it can be quite confusing. Make sure you follow the directions carefully.
aftermath is offline   Reply With Quote
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
Tire Pressure Monitor Systems Bluto Tires 68 09-21-2011 06:59 PM
Micro-Pulse Systems Monitor Bites the Dust Wayne&Sam General Repair Forum 22 08-25-2011 08:04 AM
Winterizing by-pass not working correctly tmeagle1 Water Heaters, Filters & Pumps 6 10-15-2010 06:57 PM
Systems monitor Jack46 2006 - 2010 International 4 05-20-2008 08:06 PM
