Old 07-18-2010, 09:20 AM   #1
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Red face Submarine Twinkie DIVE DIVE
I'm still in the process of restoring the twinkie with little things still to do, like a slow drip from the shower head, no big deal I thought .
A few weeks ago I forgot and left the water pump on after parking the twink and two days later I went in to tinker a bit and found the shower pan half full??? Hmmm what clogged the drain I wondered? Then I realized the original faucet was still merrily dripping away, AHHHH.
After pouring a little bleach in the pan now filling nicely I pulled the grey water drain and let out the 12 or so gallons that had accumulated in 2 days from the slow drip, (it's true a dripping faucet is a lot of water). Well grey water system is water tight, unscheduled test done, no leaks .
I found a couple of new washers at the friendly Home Depot, replaced them and success, no drip drip anymore but could have been a nasty surprise since I just filled the fresh water tank (30 gallons) when parking it to clean it out (a cup of bleach added as well to sanitize it).
So beware of a simple drip, could turn your twink into a submarine.
Come to think of it leaving a water hookup on with the mixmatch copper, pex, plastic hose stuff the PO's installed, NOT GOOD.
Project water line coming up next.
arcamedies is offline   Reply With Quote
Old 07-18-2010, 09:57 AM   #2
RV shower heads, are designed to have a small drip when shut off.
That's to remind you, that the shower hose is pressurized, because the faucet is on.
Doesn't matter if the pump is on, or the coach is hooked up to city water.
Shutting the faucets off, stops the shower head drip.
Old 07-18-2010, 11:33 AM   #3
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Drip Drip faucet turned off
shower head button set to open position, faucet was turned off, forgot the pump switch after washing hands working on project #87.
After replacing the original 35 year old washers, flattened from use, the drip stopped, do remember some drip in the 3 year old motorhome but stopped at water break after hose empty, used the same shower line and head, liked it. I would replace the original shower faucet set but doesn't look simple built the way it is from Airstream.
Old 07-18-2010, 11:48 AM   #4
r carl's Avatar
Lin , Ne
Thanks Andy, i was wondering why my shower head dripped when i turned it off with the dial.
hello, noobi getting ready to dive in adveture950 Member Introductions 8 04-18-2008 02:54 AM
Took a Dive into the Deep End! Pinkerton Member Introductions 13 11-11-2006 03:00 PM
Twinkie shaped Motorhomes Silvertwinkie General Motorhome Topics 12 03-06-2003 11:20 PM
Submarine Theme? 68 Suburban General Interior Topics 14 10-25-2002 03:44 PM
