Old 08-24-2013, 07:00 AM   #1
2007 25' Safari FB SE
Yarmouth , Maine
Strong, sulfur-like odor from faucets
Greetings, We've had our AS at a park for the last several weeks. No hookups - just boondocking. I noticed that the water coming out of the faucets (particulalry hot water faucet, though I haven't used our hot water heater) has a strong sulfur-like smell. I read on-line that if the water isn't used for several days that it's necessary to 'run the faucets' for several minutes to get the 'gas' (?) Out of the water lines. And, it further cautions that if you don't do this and fire up your water heater it could be dangerous. The AS is back at home, hooked up to city water and I've run the faucets for several minutes (hot and cold). The smell remains, particulary for the hot water lines. Any suggestions? Should I sanitize the fresh water tank (although empty at this point)?
LavenderMoon is offline   Reply With Quote
Old 08-24-2013, 07:23 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
You won't have success sanitizing your fresh water tank; that's not the problem.
You need to flush your hot water heater with vinegar. You probably have a Dometic water heater, and if you have the manual, you'll find instructions there. If not, you can download one from their site.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 08-24-2013, 08:06 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
^^2++
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-24-2013, 08:08 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Or maybe an Atwood. Their manuals are harder to find online, but they ARE out there.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-24-2013, 08:15 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Flushing will help a little. The root of the problem is most likely a disintegrated anode rod. Easily replaced.
Old 08-24-2013, 09:44 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
No anode rods in 2007. Could be from your last water fill. There is a harmless bacteria in some water that gives off this odor. Disinfecting and flushing - including the hot water tank- will fix it.
