Old 07-06-2009, 04:33 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
stream is steady
Hi! first let me thank those who responded to my previous thread about a weak stream. I started tracing the water lines and on my 345 there is a large(5"x12")inline filter under the curbside twin and attached behind a bulkhead that is not easy to see. This filter was clogged reducing my water pressure to a small stream. This filter is glass so be carefull in the removal...I used an oil filter strap wrench that worked well. Once again Thanks all and I hope my problem and solution will help someone else.Pete
pjude is offline   Reply With Quote
Our First 'Stream Stephen Mick Member Introductions 14 08-19-2008 06:35 PM
Which Stream? dannyo Trailer Values 30 05-23-2008 02:57 PM
New foot in the stream mojo Member Introductions 4 05-19-2007 07:16 PM
New to the Stream J5Stream Member Introductions 5 11-21-2006 07:58 AM
