Old 07-19-2014, 11:12 AM   #15
2010 25' FB Flying Cloud
Davenport , Iowa
I have city water that has been treated with chlorine, isn't that good enough to sanitize the lines? I usually fill with our city water before traveling.
Airtandem is offline   Reply With Quote
Old 07-19-2014, 11:30 AM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
No You need a greater concentration of chlorine to kill anything that might be lurking in there.
Aaron
WBCCI #XXXX AIR #2495
Old 07-19-2014, 12:47 PM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
City water that is treated with chlorine must have a concentration low enough to still be drinkable, meaning less than 4 parts per million. That's enough to make sure no microorganisms can live in the water between the water treatment plant and your faucet, but only because ALL of the water is treated ALL of the time.
In your Airstream— or any other RV— you're not adding chlorine all the time. The chlorine that's in the city water you used to fill your tank will evaporate in 24 hours or less because you're not constantly adding more to replace what evaporates. And when all the chlorine is gone from the water, harmful microorganisms can grow. So you periodically shock-treat the freshwater system by adding a much larger dose of chlorine, more than is safe to drink, to make sure that whatever might be adhering to the tank walls, pipes, valves, etc. is well and truly dead. Then you flush out the chlorinated water to get rid of the non-drinkable water and the dead microorganisms.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Do you sanitize hot water tank with bleach? bonginator Fresh Water Systems 2 05-14-2013 05:06 PM
It’s amazing what a little elbow grease (and disinfectant with bleach) will do. Sprouty All Argosy Trailers 2 04-18-2013 12:56 PM
How do you pour bleach into freshwater tank ? dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 10-29-2012 06:52 AM
Sanitize Black Water Tank with Bleach Air-Texas Waste Systems, Tanks & Totes 47 12-03-2011 05:54 PM
moss mold and other green stuff - bleach? cammur Cleaning, Stripping & Polishing 7 04-14-2007 07:06 AM
