Old 01-16-2004, 12:00 PM   #1
Confused & Wandering
Theo's Avatar
1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
sterilizing water lines.
Due to the crud build up in the plumbing, the offensive odours, and a lack of blind faith, I need to sterilize the water lines. This is not a problem, I have access to medical grade non toxic disinfectants that make chlorox look like a mouthwash. What is puzzling me is how to introduce it to the nastiest area - the water inlet pipe, at the rear. This is without cap, and crud has entered, partially blocking the pipe. I gouged it out, clearing the obstruction and now wish to disinfect it, under pressure..
There must be a way to do this, but it eludes me at present - I need to find something to introduce a liquid to the flow of a hose pipe, connected to the line, so it measures disinfectant to the stream, thus cleaning the entire plumbing system.. Any ideas?
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 01-16-2004, 12:08 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Theo,
Are you playing 20 questions? If you are your quota is up But if you own a vintage airstream the list will continue
I sanitize my entire system using a bleach mix poured into the onboard fresh water tank, then turn the pump on, it will pressurize all the way out to the city water fitting (if your check valve is broken or removed) To sanitize the fitting itself I just took it loose and dunked it in a small plastic bucket of what I was using to sanitize the rest of the system with.
Aaron
Old 01-16-2004, 12:47 PM   #3
Images: 59
sterilize
You need to do it in four steps:
1. Remove the crud first. Sanitizers are more effective if the crud is gone first. Use an acid type cleaner and let it sit for a few minutes.
2. The sanitizer needs to completely fill the pipes to be effective. Hook up a water hose and purge the system until all the air is removed. Bleed all deadlegs and valves.
3. You don't need to sanitize under pressure if all the air is removed first. Just mix the sanitizer and water in a bucket and use a siphon to introduce it to the piping system. Use a hose on the outlet side of the plumbing system to control the flow rate. If the bucket is above the highest point in the plumbing system and the outlet hose is at ground level it should flow through the system ok if there aren't any open faucets. Let the sanitizer sit for the the time period as directed.
4. Flush with clear water.
Old 01-16-2004, 04:33 PM   #4
Theo's Avatar
1993 34' Excella
Thank you guys. that makes it easier..
20 questions.. I wish that was all I had. The more I do, the more questions arise. I ask about 30% of them here, the others I find in the search facility, or can figure out myself..
Theo
