Old 04-08-2011, 09:03 AM   #1
New York , New York
Steel or plastic water tank?
Hello all. This is my first post.
I have an 83 airstream excella and was wondering what type of fresh water tank these have in them?
I don't want to remove some of the sheet metal underneath just to find this out. Can some one chime in on this?
Bo2020 is offline   Reply With Quote
Old 04-08-2011, 09:48 AM   #2
SteveH's Avatar
Common Sense , Texas
First, welcome to the forums.
Way early on, like in the 60's, the water tank was aluminum, and that was the pressurised one.
I don't know exactly when they changed, but they are plastic now, and have been for quite a while.
Regards,
Steve
Old 04-08-2011, 09:59 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe the early pressurized water tanks were in fact galvanized steel, not aluminum.
A 1983 trailer would have a plastic tank. The switch away from steel took place in the early 1960s.
Old 04-08-2011, 10:02 AM   #4
SteveH's Avatar
My father had a '61 31' that had a pressurized aluminum tank in it. Don't remember the year of his next Airstream, but it had a plastic tank with the demand water pump....the one with the belt, crank shaft, rod, and piston/diaphram.
Regards,
Steve
Old 04-08-2011, 10:07 AM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Our '83 Excella has a plastic tank. It is held in place by the bolted on pan. there are no straps holding the tank.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 05-31-2011, 03:00 PM   #6
1962 24' Tradewind
bull Shoals , Arkansas
Smile galvanized steel
Bud here; I have a galvanized steel 14''X 60'' that has a 4'' tear in it.
It has a air pump that pressure the tank to push the water up the pipes.
Can I use a plastics tank and will hold the 50/60 pounds, and change to a water pump.
Thanks 24/62 tradewind
ottenot is offline   Reply With Quote
Old 05-31-2011, 03:49 PM   #7
Images: 59
You can use a plastic tank with a water pump. 50/60 lbs is about 6-7 gallons.
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
