Old 06-22-2010, 02:55 PM   #1
1986 25' Sovereign
Plant City , Florida
Stainless steel hoses
Has any one considered using braided stainless hoses for there fresh water supply through out the RV? I have found a source for this that is vinyl coated stainless braid for $.75 per foot. I think that I would need around 100ft of this but if I measure twice cut once I could order the pre made hoses and just connect them together with brass fittings. I don't think I would ever have an issue with this system as they are rated to 2600psi and because they flex very well will be resistant to vibration and maybe even freezing.??
ck21084 is offline   Reply With Quote
Old 06-22-2010, 02:59 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They're usually rubber on the inside, which will deteriorate with the passage of years. Why not use PEX?
Old 06-22-2010, 03:01 PM   #3
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
That's exactly what I did. Braided stainless steel throughout. The only copper I have is the distribution manifolds I made up. We couldn't be happier...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-22-2010, 03:03 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You would also need to make sure that these hoses are designed for potable water use.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-22-2010, 03:10 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by ck21084 View Post
... will be resistant to vibration ...
You should also be aware that the braided stainless steel lines can be very abrasive to anything they rub against. The stainless strands are very hard and can act like a file if not well secured.
They can also have individual broken strands that are very small (and hard to see) protruding outward from the hose like tiny needles. I learned this handling oil lines from engine blocks to turbochargers. Usually involved profanity at the time.
Vaughan
Old 06-22-2010, 03:37 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Do what you will appreciate
... they are rated to 2600psi and because they flex very well will be resistant to vibration and maybe even freezing.??
Frozen water will ultimately win. Maybe not immediately, but eventually.
Braided SS hoses will certainly look really cool, but is the additional cost really worth it? With the exception on an 18-inch hookup line to the toilet, my Airstream's fresh water supply system is all copper, and the looks of it makes me smile every time an access door is open.
In seven years, no one has ever asked to see the plumbing, and I have never made anyone look at it.
If you want SS hoses then go for it. Be forewarned that, other than you, there may not be an appreciative audience.
Tom
Old 06-22-2010, 09:25 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Just a story to point out there are varying degrees of "braided stainless steel" hose...
My brother in his new house with new appliances, etc. had (cheap?) stainless hose from a big box store burst anyway - washer connection went two hours after they returned from vacation, then the midnight call to clean up people who stormed the house and tore out carpet, padding and moldings & set monster fans a going to save the drywall.
If you are lucky enough to get true aircraft or racing quality hose wholesale or at cost go for it - but counting on an unknown wire braid and liner hose to perform like a higher price hose may not work out like we want it to..
Wabbiteer is online now   Reply With Quote
Old 06-22-2010, 10:12 PM   #8
1977 31' Excella 500
plano , Texas
I wish I could find a Stainless Steel sewer line. I can't stand how the super mega duty vinyl ones fail. Any providers out there?
-thomas
tschat is offline   Reply With Quote
Old 06-22-2010, 10:16 PM   #9
moosetags's Avatar
-thomas
Take a look at the Sewer Solution thread, and dump the slinky.
Brian
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Is Stainless Steel Corrosive to Aluminum? ts8501 Exterior Restoration Forum 14 01-14-2013 08:12 PM
Liquid Stainless Steel? Hank A General Interior Topics 49 07-29-2012 10:29 AM
Stainless Steel Cleaning help surferstyler Interior Restoration Forum 10 08-23-2006 05:44 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
