Old 10-16-2015, 01:53 PM   #1
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Sport 16 freshwater drain valves? 2014
Is there a diagram of the freshwater system online somewhere? Failing that on my sport 16 I'm draining the tank, there is a drain valve through the floor, there is also another valve between it and the tank. What is the purpose of that valve? Do you shut this valve off for normal use? I'm guess it has something to do with the city water system? Thanks
jtwind is offline   Reply With Quote
Old 10-16-2015, 04:31 PM   #2
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
The second drain valve is for the hotwater tank. Open it, then pop the pressure relief valve on the HW tank and it will drain. I would still take out the drain plug on the hot water tank for winter storage to guard against freezing.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Old 10-17-2015, 07:55 AM   #3
Madison , Wisconsin
I might not have described it well, this valve is right up against the freshwater tank, doesn't drain through the floor. It's between the freshwater tank and the through the floor drain valve. I believe my trailer only has one through the floor drain. There is no separate hot water heater drain on this trailer or at least none of the information I've seen mention it.
Old 05-14-2018, 06:51 PM   #4
2014 16' Sport
Seattle , Washington
Did you ever figure this out? I have a 2014 Sport 16 and have same question.
ElisabethT is offline   Reply With Quote
Old 05-15-2018, 04:11 AM   #5
2015 16' Sport
Lakeridge , Virginia
The 16-ft. model has two drain valves that are located
under the roadside dinette seat. The one closest to the water tank is to drain the tank. The other drains the water system.
Peanut is offline   Reply With Quote
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
1977 airstream tradewind freshwater drain lance3787 Fresh Water Systems 2 08-07-2011 10:29 PM
Freshwater tank drain plug on 08 23FB? bonginator Fresh Water Systems 1 09-06-2010 08:03 PM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
